what is so bad about gen ii engines?
    • 13522
    #31
    Stating that a 3400 can flow more is implying comparative testing has taken place to be proof against the 3500.
    Wish I had a flowbench, no other job, and ambition to do those comparative tests you are talking about.
    • SwiftDrift
      ...But what if-
      • Dec 2013
      • 204
      #32
      i wanted to use the 3400 plenum so i didnt have to spend money that i dont have on some throttle body and supplies to hook it up.... 3400 intake+tb is farrrrrrr cheaper and easier to set up.
      edit:also i need tools to make an adapter
      Firebird: The beta version
        • 13522
        #33
        if its farrrrrr cheaper to use a 56mm tb over a 65mm tb, then there is no point in talking about 3400 vs 3500. Cheapest option is stock 3400.
        • SwiftDrift
          ...But what if-
          • Dec 2013
          • 204
          #34
          i was going to get a 3500, but pay an extra few bucks to get the intake from a 3400, hell the dude would probably tell me i can just take it.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            #35
            why do you want a 3400 intake? the 3500 intake is a common performance swap on 3400's. seems backasswards to me.
              Originally posted by IDCavalier View Post
              So, sorry to thread jack, but is the 3500 NOT considered a genIII? It's a kind-of fourth gen, right? Called the High Value engine?
              Just wondering. I want to get the nomenclature right, so when I start another build, I can at least know what I am asking! LOL
              Thanks again Dave for your sage advice!
              the 3500 LX9 is a gen 3 engine, just the last revision. the Gen 4 "high Value" 3500/3900 is where there was a redesign of the block and many other changes. Those are the LZ engines.
              • SwiftDrift
                ...But what if-
                • Dec 2013
                • 204
                #37
                i want a 3400 intake because i dont have to make an adapter and spend loads of cash that i dont have on a tb... besides isnt the 3400 plenum just about as good as the 3500s? i know they are different, but i heard they are not that far off
                • caffeine
                  • Jan 2012
                  • 1489
                  #38
                  Why are you worried about the cost of a TB vs. Cost of a TB + plenum?
                  '86 Fiero, 3500, 4-speed
                  • SwiftDrift
                    ...But what if-
                    • Dec 2013
                    • 204
                    #39
                    while im at the junkyard, after purchasing the 3500, i was going to get a 3400 sfi plenum and tb. most likey dirt cheap or free... vs. saving up several paychecks to blow on a tb and creating an adapter to use it.....
                    • caffeine
                      • Jan 2012
                      • 1489
                      #40
                      Several paycheques? Most pull-it-yourself places seem to only charge about $30 for a throttle body. If you have a drill and a holesaw set you can make yourself an adapter plate for $5-10. I did.
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        #41
                        agreed.
                        honestly, if you can't swing a junkyard TB, you might be better off going job hunting.
                        • caffeine
                          • Jan 2012
                          • 1489
                          #42
                          Or don't buy coffee for a month
                            • 9189
                            #43
                            I guess I'm just confused about your entire project. You are wanting to build a Camaro for drifting and are talking about all of the mods needed for drifting, but then you are concerned about the cost of a TB and adapter. Sounds like you need to make yourself a plan and figure out a budget before you go much further along. It'll help in figuring out what questions you really need to be asking.
                            Brad
                            via Moto X
                            • caffeine
                              • Jan 2012
                              • 1489
                              #44
                              Ya a proper suspension setup will cost more than a motor swap. Steering angle would probably be the first thing to address IMO.
                              • 34blazer
                                • Sep 2007
                                • 341
                                #45
                                Anybody mention the cost of tires???
                                '86 Grand National
