Oil Filter Modifications
  • Futures Passed
    • Jun 2011
    • 46
    I've never really gotten an answer I'm happy with on the debate on longer oil filters versus OEM size; it always falls into a bigger-is-better versus never-question-an-engineer argument. I'm only asking here because you guys have been much more in depth with technical questions, and I feel like I'd see some new stuff here.
    Also, I'm wondering if any of you run neodymium magnets on your filters to help catch finer particles. I got a small set of coin-shaped ones so I could stick one on the end, but as soon as I put it on, I instantly realized that it might be strong enough to pull on the anti-drainback valve spring, so now I have bars along the side. However, I do know there is only so much it can catch with an aluminum block.
    Have any other oil filter modifications?
    - Stephen Brand
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Mr. Brand,
    The large volume filter can absorb more particle contaminates and possibly go longer intervals with maintenance when compared to the shorter filter with the very ever so slight benefit of more oil to aid in providing a very miniscule oil cooler affect. My main concern to a large filter is the initial dry start up after a spill and fill or if the filter is orientated a certain way in which doesn't allow oil to retain full capacity after shut down.
    Sometimes this is mitigated by an oil filter relocation kit, but other times it may not be cost effective or just not feasible to the application.
    I've always ran the PF52 over PF47 when space allowed, price was right, and inventory was available. Additionally, I find it very important to make sure any filter being used has an anti-drain back feature.
    FYI, these blocks are iron with aluminum heads.
    Your link to "Cars Simplified" is not valid.
      i've found that on a W-body, there is no reason to run a PF47 size cannister if a PF52 size is available, there extra length hasn't caused me problems. other platforms, i can't speak for. i fill the filter with as much oil as possible(and letting it soak through into both sides of the element) before spinning it on to minimize dry running time without spilling too much on my arm. with all of the 60V6 W cars i've had, the filter sits at roughly a 45* angle to the ground(maybe 60 would be more accurate?), though i've never had issues with the ADBV letting oil back into the engine after shutdown, even with cheap rubber ADBVs as opposed to the silicone ones used in more expensive filters.
      i have some neodymium button magnets that i've thrown on the end of the filter as well, i don't know if they've actually done anything positive or negative and while strong, i don't think they're strong enough to move the cartridge portion of the filter down at all.
      • carbon
        Procrastinator
        • 388
        Ditto on the PF52 with my Fiero, Grand Am and Saturn Relay minivan....
        - Ben
          i want to say there was at least one platform that used an adapter that moved and rotated the filter to where it would point straight up and down but the length of the PF52 would have extended past the subframe where the PF47 didn't? sounds like the easiest and least messy filter ever.
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            The Beretta 2.8s I had were equipped with vertical filter positioning.
            • carbon
              Procrastinator
              • 388
              My 3500 engine came with one of those adapters... I believe it came from a Malibu.
              - Ben
                • 13531
                Is there an argument for a smaller filter?
                  Weight reduction and space used?
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    Tree huggers against recycling more waste product (oil & filter elements) ?
                    • geoffinbc
                      Iron Head Enthusiast
                      • 5831
                      I have the biggest filter that was used on common passenger car engines. It is a Delco PF2C or Baldwin B2 it holds a full quart of oil and I have it mounted vertically on a remote mount. I do extended drain intervals so it is a little extra assurance.
                      As far as I see as long as you fill it up as much as possible when doing a change you have nothing to worry about. The other thing you can do (if you can't get oil into the filter) is disconnect the fuel pump and crank the engine until pressure builds on the gauge. This will ensure there is no load on the bearings while they are rotating.
                      • Guest
                        I used to disable the ignition system. Now, oil pressure seems to build so quickly with the better oiling systems that I don't even bother with that anymore.
                        • Blacktree
                          '87 Fiero SE
                          • Dec 2006
                          • 48
                          For Fiero owners, the AC Delco PF52 (or equivalent) is very popular. It fits both the 4-cyl and V6 engines in our cars.
                          • 45es
                            • Oct 2010
                            • 75
                            Another source for the vertical filter adapter is the '97 - '98 Grand Am 3100. I purchased one today.
                            Ed
                              I still have one from a 3500 sitting around if anyone wants it. Just shoot me a pm.
