more power from a 3100
  • mrjoseloza88
    • Feb 2014
    • 13
    new guy here, i have a 3100 malibu, it has a ported 54 mm intake from a 3400, ported upper and lower intakes, fuel pressure regulator from a 3400, air intake and 2 1/4 cat back exhaust, down pipie is stock... which is in the works to be upgraded to 2 1/4 piping to match the cat back. I need a tune to pass emissions and get more HP, maybe a walbro fuel pump upgrade, ive been told to upgrade my springs to LS6 and get a cam but dont know how to pick cams
    what can i do to get more power? any suggestion or ideas would be awesome.
    turbocharging wont happen anytime, looking for an all motor build
  • Canyonero
    Plays with Volvos now.
    • Sep 2006
    • 1112
    NOS
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Nitrous wet system coupled with higher compression might get you where you want to be on a stock tune.
        Talk to Ben from WOT-Tech. He has a cam selection service. His screen name on here is SappySE107.
          goals? budget?
          staying N/A, cam, heads, compression.... you've done most everything else.
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            Originally posted by mrjoseloza88 View Post
            new guy here, i have a 3100 malibu, I need a tune to pass emissions and get more HP, .
            That makes a cam option very limited unless the OP is willing to tune.
            • mrjoseloza88
              • Feb 2014
              • 13
              goals? im trying to get at least 200 hp, as of now limited to almost no budget, im looking to tune when i get a cam with my tax return. As far as higher compression how can i achieve that, besides pistons and or having my heads machined.
              • Canyonero
                • Sep 2006
                • 1112
                Sell it and buy a a BMW E46. About 200hp from the 328i, available 5-speed, RWD, fantastic cars.
                Sent from my XT1058 using Tapatalk
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  Wheel or crank?
                  • mrjoseloza88
                    • Feb 2014
                    • 13
                    not bad but would settle for a m3, cant get new car till wife's suv is paid off lol
                    • mrjoseloza88
                      • Feb 2014
                      • 13
                      to the wheels if possible, if not the crank, im not picky
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        Cam, headers, ported intakes, TB, CAI, tune, and 50 shot. That should put you over 200 at the wheels.
                        • mrjoseloza88
                          • Feb 2014
                          • 13
                          where can I get a tune, the car needs it. The car hasnt been running right after all the mods I did to it, it wont pass inspection runs too lean, and then goes to being too rich. Is there any way I can tune it myself?
                            • 13534
                            We can tune the PCM but need to know what that 3400 FPR is as far as year. There is no difference between a 3100 and a 3400 regulator. Year is what matters. Other than that, nothing you currently have should be causing you any issues.
                            • mrjoseloza88
                              • Feb 2014
                              • 13
                              Got the FPR from a same year 2002 3400, fro my 2002 3100, parts store didnt have any 3100 in stock and i didnt want to waste time looking for one.
