3400 injectors in my 94 Z26
  • BerettaZ26
    BerettaZ26
    • Mar 2014
    • 24
    hey everybody been doin some research on 3400 injectors to see if its worth the time to ditch the 3100 ones with 3400 ones, Is there any wiring problems I would run into, and do I need to get the fuel rails to take full advantage of the new injectors? Any help will be greatly appreciated.
    Thanx in advance!!!!
    1994 Chevy Beretta Z26
    CAI
    180 degree thermostat
    high flow muffler
    3400 V6 Throttle Body
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Are you going to reflash the PCM at the same time of changing the injectors?
      • 13522
      Other than the newer injectors being less prone to clogging, what benefit have you found from your research? I wouldn't recommend changing injectors unless necessary, which you are no where close to right now.
      • Purple pit
        • Oct 2012
        • 718
        Put the big port 3100 or a 3400 intakes on and you can use 99 Venture Van 3400 injectors. They are a direct plug in. If your lucky on Rock Auto you can get them at a good price. The Delcos are a nice upgrade vs the old stock. Much better spray pattern for a nice idle.
        Grand Prix trans with 3.33FDR
