Camshaft for torque increase? Options? Need 30ftlb
    • 13531
    Even the street/strip cam runs great on the stock tune. OBD2 with its MAF really takes care of the fueling quite well, and the stock spark table is pretty damn good as well. OBD1 owners can't appreciate this fact I guess The VE tune for the torque cam is crazy compared to stock but without seeing it, I don't know that it would be noticed. OBD1 would need a tune for sure:P But OBD2 is fine. Tuning for the cam is possible...but not even close to necessary. Its the transmission and other small details like fans and TCC that make the big difference in tuning.
    • beigmatt
      • Jul 2013
      • 40
      As far as I know engines are tuned from the factory to run just a tad rich and under powered to help with MPG and emissions. A stock tune is based on certain a certain specification range based on certain parts.
      Example: Engine is running a tune to accommodate lifters with a length anywhere from (+-0.0xx). More accurately measuring your engines camshaft, push rod length, hydraulic lifter timing (within a range ofcourse, because its not a solid lifter), fuel map, ignition timing, fuel, etc... will allow you to put a more aggressive/powerful tune in if you know your engine can handle it.
      So what about my camshaft? Can anybody help?
        • 13531
        http://www.ebay.com/itm/Unused-2005-...d27e38&vxp=mtr
        This is your best bet.
        • carbon
          Procrastinator
          • 388
          Yup... factory service manuals are awesome.
          - Ben
          • beigmatt
            • Jul 2013
            • 40
            Anybody else have any recommendations? Should I buy head gaskets on WOT-tech? I keep this engine as cool as possible but I know that Is the first thing to go on these engines. It happened with my last one.
              • 13531
              #21
              If you are pulling the heads to put valve springs on, then you need new gaskets. Checking the heads for warpage is a good idea while its apart and milling if necessary.
