300 hp N/A carb 2.8 V6 engine
    • 13522
    #166
    What size is the hole on the 3400 heads?
    • veekuusi
      • Aug 2011
      • 205
      #167
      I think that the thread is 1/8 NPT in the 3400 heads.
      The hole in the 3100 heads is 2 mm bigger , some 11 mm.
      • 34blazer
        • Sep 2007
        • 341
        #168
        1/4 npt
        '86 Grand National
          • 13522
          #169
          Learn something new every day. I have never seen a 3400 with that coolant temp sensor in the cylinder head.
          • Guest
            #170
            Neither have I.
            • veekuusi
              • Aug 2011
              • 205
              #171
              I found a suitable fitting today.
              "Reducer" , or what you call it.
              I quess it is 1/8 NPT to 1/4 NPT ?
              And there certainly was a 1/8 NPT thread in those 3400 heads , that I was using.
              The thread was only in one cylinder head (for coolant temp sensor) , I had to make
              the 1/8 NPT thread to the other head by myself (first drill a hole of course).
              I need those fittings , because the water outlet is in different place in head , I think otherwise
              there can remain air in the head .
              • Guest
                #172
                That must have been something you did then, is that what youcre saying?
                The small port 3100 heads had a temp sensor located in that position in many applications.
                • Will'sFiero
                  Too many valves
                  • 276
                  #173
                  "Reducing bushing"
                  Current:
                  \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
                  \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
                  \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
                  Gone, mostly forgotten:
                  \'90 Pontiac 6000 SE AWD: slow but invisible
                  • veekuusi
                    • Aug 2011
                    • 205
                    #174
                    I got the engine running all right.
                    But it made an interesting sound.
                    It took a while to figure out , what was wrong.
                    Starter motor gave up.
                    Bendix in the starter motor do not work.
                    The gear of the starter jammed to the fly wheel .
                    It takes a few days to get a new starter motor.
                    • Purple pit
                      • Oct 2012
                      • 718
                      #175
                      3400/newer style starter? Just put on a gear reduction myself and now have some teeth missing on the flexplate. Not sure if a shim would do anything for us. Bendix is not a cheap starter, my Airtex kind of was.
                      Grand Prix trans with 3.33FDR
                      • veekuusi
                        • Aug 2011
                        • 205
                        #176
                        I got a new 3400 reduction gear starter.
                        150 euros (including tax) , something like $ 170.
                        • Purple pit
                          • Oct 2012
                          • 718
                          #177
                          Do you think it needed a shim or was it not lined up somehow? Or was it a bolt torque problem and the bolts came loose just enough to take it out of line? Hard to blame the starter, those two look the same.
                            Live life 3.7mi at a time
                            • 4555
                            #178
                            How many engine starts did that starter have? seems premature.
                            • veekuusi
                              • Aug 2011
                              • 205
                              #179
                              You are right.
                              Maybe hundreds of starts. There has been big difficulties to get the engine running in
                              the past few years.I mean long starting times. The starter has suffered a lot.
                              It has taken a beaten.
                              Certainly not loose bolts is the cause of the damage.
                              But now with the new starter, everything is OK.
                              • padgett
                                VeloCity CarPets
                                • Apr 2016
                                • 11
                                #180
                                Long starting in a GM car is usually the fuel pump relay. When it fails you have to crank until the oil pressure comes up before the fuel pump will turn on.
