Help with cam selection
    • 13525
    This is our listing for the flat tappet cam. You can use a shelf cam for less but they are designed for iron heads or at best, the gen 2 aluminum top end.
    • trebec
      • Nov 2014
      • 19
      For under $100 you can be tuning the 93 Camaro PCM properly yourself, plus you get to keep SFI. No messing with fuel pressure or timing.
      hey caffeine, I want that. are you referring to "megasquirt"?
      • trebec
        • Nov 2014
        • 19
        http://wot-tech.com/shop/gm-60v6/per.../prod_306.html
        Thanks, now I know where to buy the cam.
        • caffeine
          • Jan 2012
          • 1489
          I'm not talking about megasquirt. I'm talking about using the factory 93-95 PCM and tuning it.
          '86 Fiero, 3500, 4-speed
          • trebec
            • Nov 2014
            • 19
            How can I do that for <$100? What would I need to buy?
              TunerCat released support for the 93-95 3.4 PCM a couple years ago. You can either buy Winflash and use Tunerpro with Robert's definition file or you can buy the full Tunercats program. I've flashed them before. Tuning wise it's about the same as a 7730 except the flash process takes a few minutes. But it's cheaper because you only need a cable and Winflash ($20) vs buying a chip burner or emulator
              Dude, READ THE POSTS!
