Quick Cam question...
  • shrike
    • Apr 2015
    • 29
    Will a 2.8 cam run in a 3.4 block ??... Are all these castings the same ? I want a cam for a 3.4 block that will run an old school distributor from the 2.8's
    Hydraulic roller ?
    Thanks...
  • Heartbeat1991
    • Mar 2013
    • 68
    2.8 was a flat tappet hydraulic. 3400 is a hydraulic roller.
      • 13525
      there are flat tappet 2.8 3.1 and 3.4 engines. What 3.4 engine are you talking about? 2.8 never had a roller cam from the factory. They can all run a distributor.
      • shrike
        • Apr 2015
        • 29
        Thanks you guys... I have a 95 camaro 3.4 that I want to run a hyd roller cam in and an old school 2.8 dist...
        Thanks for any help and advice on this!...
          • 13525
          You will have to keep the lifters from rotating but its been done before. You will probably want a custom cam made for the flow of the iron head engine/carb vs the roller cams we designed for the aluminum head/fuel injected engines. If that is something you are interested in, ben at wot-tech.com is my email.
          • shrike
            • Apr 2015
            • 29
            Thank you Ben...
