Dishes, Domes, Compression Heights and Chamber Volumes
  • Guest
    yup gm lists the 3.4 iron head gen 1 as being 9.0:1 compresion. NOT 9.6:1
    • Will'sFiero
      Too many valves
      • 276
      I guess I'll post in the DOHC section for that chamber volume.
      Thanks guys
      Current:
      \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
      \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
      \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
      Gone, mostly forgotten:
      \'90 Pontiac 6000 SE AWD: slow but invisible
      • Will'sFiero
        Too many valves
        • 276
        New info on TDC's:
        Code:
        Application     Dish/Dome     C/H
        2.8 LO          0 cc's        1.578
        2.8 HO          0 cc's        1.599
        3.1             12 cc's       1.450
        3.4             8 cc's        1.457
        2.8 Gen2        21.2 cc's     1.608
        3.1 Gen2        26.4 cc's     1.450
        3100            24.5 cc's     1.470
        3400            27 cc's       1.460
        TDC             5 cc's        1.457
        DOHC            5 cc's        1.457
        Head     Chamber size
        Gen1     48.5 cc's
        Gen2     26.4 cc's
        Gen3     26.4 cc's
        TDC      54.0 cc's
        DOHC     51.5 cc's
        Misc: Gen2 stock head gasket: 0.060
              Gen1 stock head gasket: 0.040
        Current:
        • v6h.o.
          • 1418
          My Sealed power piston book has these numbers listed for Compression Height:
          2.8L
          Compression height 1.598 or 1.578
          3.1L vin "T" and "D" 1.442 comp height.
          3100's 1.480
          3.4L 93-95 "S" iron head 1.450
          3.4L 96-03 Ld Truck/Car 1.478
          3.4L DOHC 1.464 (uses 1.20 top ring, 1.50 2nd, 3.0 oil)
          or 3.4L dohc 1.458 Plus .040 DOME. (uses 1.5 top and 2nd rings, 4.0 oil)
          Colin
            • 13524
            Ok, so the gen 2 aluminum head pistons have the same cc as the head chamber?
            • GPXSS
              • 588
              #21
              might find some info here:
              http://www.60degreev6.com/GPXSS/engine-pistonspecs.htm
              I modify stuff
