3x00 Cam Update!
    • 9191
    3x00 Cam Update!
    From 3x3 on GAGT.com
    Thanks to Chris White & Colin for their help in getting me what I needed to get to this point. We are very close to getting the cam. I got off the phone today with my contact who will start next week in making 100 cam cores. After this is completed Comp Cams will purchase the cores and will put out a press release along with part numbers. There will be 4-6 versions of the cam but of course you could request for a special profile. Creating the cores will take 3 to 4 weeks. I was told once Comp Cams issues a press release with the part numbers that anyone can start ordering a cam. I'll keep you posted when I hear any updates.
    Here is a link to the thread: http://www.grandamgt.com/forum/showt...627#post526627
    And I'll try to keep everyone over here updated as to what is going on.
    • 13531
    Feel free to put that as news on the site:P
    • TurboZ24
      • 299
      What is the cost? I can actually get a cam for the 3100/3400 right now for 400.00 US.
      Curtis
      91\' Turbo Z24
      http://www.turboz24.com
      • Rhedalert
        Dr. Feelgood
        • 1574
        good, now will the cams be compatible with '99 prior? The cam sensor ring is different supposedly?
        Brian
        3400 SFI V6, 4T60e
          • 9191
          You can use either sensor from 94-99 or 00-02 and it will work with either cam from 94-02. The signal send to the PCM is exactly the same. The difference between the design is a single tooth versus a missing tooth. But either way, the sensor will spike at the exact same spot. Now, starting in 03 is a different story...
          • v6h.o.
            • 1418
            Yup. Hopefully that 03 Camshaft i sent them helps.
            Colin
            • geoffinbc
              Iron Head Enthusiast
              • 5831
              Could you not install an old style cam and change to an old style sensor? Or will it still not work?
              • ProjectMM
                • Mar 2004
                • 170
                Right on, about time! does any one know what the profile will be and if it will be somg legal?
                2002 Pontiac GrandAm GT1
                3400 v6
                TOG headers
                RSM 62MM T-body
                FFP underdrive pulley
                GRANATELLI MAF
                Ported upper intake
                MSD DIS 4 ignition box
                MSD Wires and coils (pending)
                Venom high flow fuel pump (pending)
                • ProjectMM
                  • Mar 2004
                  • 170
                  also I forgot to ask if it will be a roller or tapet cam?
                  3400 v6
                  TOG headers
                  RSM 62MM T-body
                  GRANATELLI MAF
                  Ported upper intake
                  • 1QUICKHATCH
                    • 387
                    3X00=roller and they should be able to make any profile once the blanks are made!
                    14.96@91.47 in the 1/4
                    9.63@74.36 in the 1/8th
                    • Berettaspeed
                      • Apr 2004
                      • 109
                      This is sounding good for us but im wondering if it will affect my 3400 because im not running the OBDII ECU. Maybe it won't help my car as much as others? does anyone know how these cams will affect people that have done engine swaps with MPFI, instead of SFI injection?
                      89 BerettaGT 3400 5spd
                      60' 2.106 street tires
                      Best ET 14.313@95.37 N/A
                      Now Boosted
                      14s@109 (poor tune still rich, poor driving skills, poor owner)
                        • 13531
                        You wont have to worry about the cam sensor, and thats about the only difference. Of course, you will have to retune for the cam to get the most benefit but OBD1 and OBD2 don't matter one bit as far as the cam is concerned.
