rod bolts?
  • oil pan 4
    • 84
    rod bolts?
    I'm loooking for new rod bolts for 2.8L-3.4L rods.
    I looked on summitracing and couldn't find any rod bolts.
    Any one know where I can get rod bolts that are better than stock or some thing that I can replace them with?
    Like maybe small jornal SBC bolts? But probly not.
    The bolts are 2.45'' long
    The shank is .33'' wide
    The lock is .362'' wide
    The bolt is a 13mm 12point
    The threds are .351'' a definat 9mm with as good as I can tell 1mm threds (9mmX1mm).
    Seth
    Camaro 1
    85\' 3.4L, T-5, 3.42gears
    Mods at work on,
    car domain site 03/13 Saab intercooler flow numbers.
    85\' IROC Z28 Ttop 5.0L, auto mostly stock.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Well can be 9mm they must be 10mm. The pitch I am not to sure of. ARP is your only hope for quality bolts otherwise use stock. There is nothing bad about the stock rod nuts and bolts on these babies.
    • oil pan 4
      • 84
      The thred dia is 9mm (.351'' is what I got with my dial caliper)and I also found it in the chevy power manual stating thay they are 9mm.
      9mm is just a hair bigger than the 11/32'' the standard SBC bolt.
      .351'' vs. .344''
      I thought ARP would have some but they had every thing but 60-V6 bolts.
      I hope GM put as much thought in the bolts as the rod being that it is forged and all. I'll get new stockers if I have to and get them treated.
      Some time I'll call summit becasue I get better luck that way when it comes to 60*-V6 stuff.
      Seth
      Camaro 1
      Mods at work on,
      • RacerX11
        • 1060
        Summit carries the ARP rod bolts that fit any 660 engine. Summit part number is ARP-133-6002, they are $48.99 for a set.
        Marty
        '99 Z-28 - Weekend Driver
        '84 X-11 - Time and Money Pit
        Quote of the week:
        Originally posted by Aaron
        • geoffinbc
          • 5831
          9MM? Well thats a odd size. Ohwell.
          • v6h.o.
            • 1418
            Marty
            Yup, i have two sets of those bolts from summit sitting in my parts pile, someday i'll use them
            Colin
            • 614streets
              • 344
              Marty
              2 sets, why you stocker you cant have all the fun.
              1992 Chevrolet S10
              2.8 v6 tbi 5 speed
              • oil pan 4
                • 84
                Thanks a lot, I searched all ARP products then searced with a key word and didn't see em'.
                Seth
                Camaro 1
                Mods at work on,
                • RacerX11
                  • 1060
                  I usually have better luck finding the manufacturer's part number from their website, then searching Summit under Manuf. PN search.
                  Marty
                  Quote of the week:
                  • keithcar72
                    • Dec 2004
                    • 7
                    ARI also carries arp rod bolts as well as many other 660 parts including head studs and mains.
                    • keithcar72
                      • Dec 2004
                      • 7
                      lets try this again
                        • 13531
                        I hope to have the ARP bolts on the 60V6 store as well. Id like to get the other bolts made though as well since they have the iron head studs, and the rod bolts. Not sure on mains and aluminum heads, or DOHC heads.
                        • sharkey
                          • Jun 2004
                          • 2061
                          rod bolts- http://www.arp-bolts.com/media/pdf_files/rod_chart.pdf
                          iron head studs- http://www.arp-bolts.com/media/pdf_files/headstuds.pdf
                          main studs- i know they have them, but they dont list them.
                          rocker studs- http://www.arp-bolts.com/media/pdf_files/rock_am.pdf (for using roller tip rockers, they are 10mm bottom and 3/8 top)
                          • Anonymous
                            It'd be really cool if we could get ARP to make a set for the 60*V6s, even the oddballs(DOHC, ironhead, etc.) I know I'd be buying them.
