I am starting to build a 2.8 iron head motor. This is a street legal race motor. this motor will see little to no actual street time. It will be run under a couple of different sets of rules. so it will have to be a 2.8, however I will be able to add 1 power adder. My current plan is to add a turbo. It will be going into a fiero 5spd. most of the racing will be autox with some 1/8 mile heads up drag racing. the internals are pretty much open though. I have most of it figured out and am on a small budget but I have a few questions and am open to sugestions.
1. what piston wall clearance do you recommend?
2. are stainless steel valves worth the money?
3. I will be porting the heads and intake my self. any key areas to watch?
4. I will be twisting its tail pretty hard so is there any thing I need to do to the oiling system besides high volume/high pressure pump?
5. since it will be a turbo engine with very frequent oil changes. Every 3 to 4 events. how do you feel about synthetic oil vs regular oil and what weight do you recomind?
