I am building a 3.4 for my suv, what are good rocker arms to use? I really dont want to keep stock.
rocker arms
RE: rocker arms
Which 3.4 are you using? RWD iron head or FWD aluminum? I believe the Crane gold race rockers will bolt on either one, or you can do like I did and use SBC roller rockers, but you have to get the ARP rocker studs with the 10mm bottom thread and 3/8" top thread. Also, the SBC rockers may need to be checked for clearances with the intake manifold, and valve covers.Franz
1990 Z24-NA 3.1L
14.72 @ 92.24 MPH
14.89 @ 94.92 MPH
The boost is coming....
RE: rocker arms
^ quite a few rocker arms for the iron heads3.4L camaro some goodies
No, they are 1.6 ratio. I got that info direct from GM Powertrain. I always thought that they were 1.5 as well, but my guy at GM confirmed that they are in fact 1.6.-Brad-
If thats the case, I have some sitting here at my place, for dirt cheap.1992 Miata B Package
1995 Regal 3100
1996 Firebird LT1 T56
Got it.Originally posted by no1kickerSlick, sent you a PM about the rockers.1992 Miata B Package
1995 Regal 3100
Really? Hmm.. interesting.Originally posted by bszopiNo, they are 1.6 ratio. I got that info direct from GM Powertrain. I always thought that they were 1.5 as well, but my guy at GM confirmed that they are in fact 1.6.Colin
Yup just plop them in.I gurentee you'll feel somthing from it. Also if you cant swing getting a chip, Get fuel injectors from a 3300 V6. I gurentee those two togther will make the engine happier.Lorenzo
