why do we buy big throttle bodies
  • Froggx
    • Jul 2004
    • 385
    I was sitting around looking to see if the RSM throttle body looked like it was worth the money. I decided to do some basic math.
    As we all know:
    Airflow rate = cid x rpm x 0.5 x Ev /1728
    where Ev is volumetric efficiency.
    I'll be working with the 3400 LA1, which is rated 204 CID according to this site.
    I'll work 6000 rpm for startes, since most of you redline about there stock.
    Math is based on stock TB
    354 = 204 x 6000 x .5 x Ev /1728
    You get an Ev of ~100% needed to max out the TB.
    Take a 20% to account for the throttle body being less than perfect, and you still need ~80%.
    Now correct me if I'm wrong, but I highly doubt our engines are pumping through a volumetric efficiency of near 80-100% at 6000 rpm.
    Let's hit the stock TB with 7000rpm now.
    You'd need ~86% VE if the TB is 100% effiecient, and ~69% if it is only 80 % efficient at letting air through.
    Let's look at the most common upgrade it seems, the 62 mm TB.
    Wow...just wow.
    At 6000 rpm you'd have to hit a VE of 123% to max it out, ~98% if the TB maintains 80% efficiency
    7000 rpm you'd have to his 105% VE, or 84% if the TB is 80%.
    I calculate stock our VE at HP peak is about 76%.
    6000 rpm stock motor I calculate about 62%
    Spun up to 7000 rpm stock and it drops below 50%
    Now let's pretend someone has modded a motor to hit 220 crank hp at 6000 rpm. That's about 175 at the wheels with 20% drivetrain loss, which is doable with a decently modded LA1, still NA. I know my motor won't beat that while it's NA
    About 81% VE is what I calculate at 6000 rpm.
    This is within 1% of the 20% safety margin I threw into the stock TB.
    At 7000 rpm I estimate VE drops to about 63%, which is once again below the safety margin of 20% I imposed, by about 6% this time.
    Now I know this is a lot of math and somewhat hard to follow, but I find it hard to justify going to a larger throttle body when my stock one seems to meet my goals just fine. Feel free to add your input to this and correct my math as I do make mistakes from time to time.
  • Guest
    RE: why do we buy big throttle bodies
    I tested a bored out tb on a stock 2.8 fiero engine.
    It went from 52 to 56 mm. It was the first bored out TB doen by Darrel Morse. They are all 57 mm now.
    I picked up 2-4 hp penidng on what rpm I was at but I saw a gain the whole rpm range
    They do work. Even if the stock one isn't maxed out you are able to get more air in with a larger tb. Its that simple.
    • Froggx
      • Jul 2004
      • 385
      I guess my question then is, is it $210 more worth of air?
      • gpse3400
        • 1460
        So far I've found that a modified engine would be more happier with a bigger tb. Hell I've found an unmodified one benefits also... For my engine if I threw a the 52 or the 56 back on it would fuck it up.. hell I don't think the 62mm is good enough for my engine...If you are buidling up an engine don't short change yourself, purchase the 62mm. Also unless you are throwing headers on, get that down pipe fabbed bigger. The rest of the exhaust can wait. You know some things are just too small...These pushrod motors have basically thoroughout it's run have had the immdieate intake and exhaust made very small. I knows the exhasut manifold deal was probably for size... but the pipe work leaving it was just in reasonable....But also youl notice now how GM played with the power for the GEN3 by making differnt tb sizes. I think I'm th eonly one whos seen it but I know they made a TB smaller than 52 and they put on a VIN J 3100 in an N-car. Note the power was 170 hp instead of 175 like the W car has. Same deal with the 3400 in an Wcar, except they had a 52mm and in the minivan it has the 56mm. Power 180 and 185 repect.
        Lorenzo
          • 13531
          Ill have 2 billet TBs for the 3100/3400 for sale as soon as kimmo gets them to me. 200 plus shipping. Yes, RSM is overpriced, imagine that. I had an LT1 TB bored out for 135...thats 2 plates as well! I had the guy look at a 3400 TB and he said the most it can be bored is to 58mm because of the IAC passage. I guess RSM welds it up but im not even going to bother with that.
          As to why a larger TB helps despite the air flow calcs....plenum volume. With a smaller plenum, you need a larger TB to compensate. Its been a while since I read through the math behind it but it was definetly beyond VE and airflow.
          • v6h.o.
            • 1418
            Re: RE: why do we buy big throttle bodies
            They sleave them with a piece of aluminum tubing.
            Colin
              • 9191
              From The Old One at Endyn (www.theoldone.com):
              All the things you're asking are good and answerable questions, but in order to provide correct answers, the rpm range from bottom to top is a necessity as is the throttle body diameter, and space limitations. The plenum volume is critical on N/A engines, and a basic rule of thumb is: The smaller the plenum, the lower the rpm range, and bigger means higher rpm. The throttle body size and flow rate also affect the plenum size: Bigger TB, smaller plenum, small TB, larger plenum.The runners work very much the same way. This is why you see so many sheet metal manifolds today in racing. Technology is moving so fast that tooling up and casting a manifold would be a really bad mistake, because, before you'd sell "any" the engines will want a different configuration, and you'd be out considerable money.
              • TheDirtyBen
                • Mar 2004
                • 130
                ummm, yeah!
                1994 Oldsmobile Achieva (2002 3100 SFI)
                Homemade ram-effect CAI
                K&N cylinder filter
                Poorboy Lowering Kit
                Front STB
