the Gran Damn
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    not a ton of progress I welded the trans mount to the frame, I may add a support to the underside, because I had to cut down part of the rear gusset to fit the LCA bolt in. I started laying out the new brake lines, and was starting to get super frustrated, it took an embarrassingly long time for me to figure out the issue. The reman front right line is two pieces instead of one, and they sent me two of the caliper side, and not one of the ABS module side... I emailed inline tube, and they sent me the correct part.
    this is the flange for the rear pipe, notice the huge gap between the pipe and the flange? filling it with weld was an option, but I had a trick to try first...
    I slipped the end of the pipe onto a 2" hitch ball, gave it a few good whacks with a hammer...
    TA-DA! no more gap.
    I started by extending the front pipe back, then carefully made a rear pipe to meet up with it.
    unfortunately, the new rear pipe didn't clear the heat shield that I had neglected to install when I made it....so I cut it apart and started over...
    after paying more attention to the spatial constraints imposed by the heat shield, I came up with this:
    overall, it's very similar to what I had before, just repositioned, and slightly longer than the previous. ideally, I wanted both head pipes to be the same length, or somewhat close, at this point, the front is a few inches longer, maybe 3-4, but much closer than stock.
    by balancing the pipe lengths, the exhaust pulses should merge with each other a little bit better, and minimize "crowding" in the rest of the exhaust past the Y pipe. I don't expect this to make a significant performance improvement, but I suspect it will change the tone of the exhaust some. my current plan is to y them together at the current end of the rear pipe, and tie them into the factory exhaust which should be close by.
    • 1QUICKHATCH
      • 387
      I think the exhaust setup should help quite a bit over the stock manifolds. I'm thinking of using both front and rear G6 manifolds with a custom crossover and Y on my Grand Am.
      14.96@91.47 in the 1/4
      9.63@74.36 in the 1/8th
        • 13520
        Got a nice metal forming tool on the back of the truck Are you looping the rear exhaust for the angle, equal length, or? I don't know what the U turn is stock but I remember reading people getting rid of something on the stock 3900 G6 setups.
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          it was looped for two reasons, one, equal length, and 2, because it was a little easier to package that way. in theory, it should smooth the pulses as the merge in the Y pipe since it's an even fire engine, which should make better use of the stock piping diameter from the Y back. I was going to finish up the Y pipe today, but elected to work on the Fiero instead. tomorrow, I'll either finish the pipe, or finish what I started on the Fiero.
          I'm really curious how the whole car will perform when I'm done with all of this... Heads, intake, exhaust, a few other things... the Five speed, new swaybars, ball joints, tierods, struts... it'll be a new car!
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            so... I haven't updated this in a while, but I also hadn't worked on it in a while... over the past few weeks, I made a mad thrash to get this car going, and it's finally back together with a few small exceptions. over the past couple months, I...
            Reinstalled the engine and trans, just to figure out my mounts had it crooked, and the exhaust didn't fit,
            installed the new struts, axles, control arms, tierods, steering rack, ect.
            cobbled together a air intake.
            fixed the brake/fuel lines
            and remade the exhaust
            after ages of sitting, and a silly amount of work, it lives again
            I made a mad thrash to get it out of the garage, and, it's out.
            I still have a bunch of little things to do, the inner fenders aren't quite right, the driver's side trans mount needs to be redone, and I should probably bleed the brakes again. oh, and it desperately needs an alignment...
            FWIW, most of what I did to this car wasn't really in the name of going fast. I put the LX9 heads and intakes on because it was less work than extracting exhaust manifold bolts, the engine needed a timing chain, and the lower intake gaskets needed to be changed, so much of this work was actually repairs, and all of the parts were just junk I had on the shelf collecting dust. admittedly, the exhaust was totally unnecessary, as was the camshaft, but it sounds awesome... I'd like to take it, and the Fiero to a dyno and see what they actually put down.
              • 13520
              #21
              I wanna see how the tune on it looks Does sound awesome. If it was a fiero, that would be 450 whp but we will have to see what happens in a Gran Damn
              • dbral
                • Feb 2021
                • 38
                #22
                Great job! Your exhaust idea is a good option that doesn't involve building a complete set of headers too.
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  #23
                  lol, well, the tune is all over the place right now. I keep having intermittent issues with my DHP Powertunr not wanting to connect... it's pretty frustrating, because I have some small changes that could make a massive difference in performance. I'd really like to get it on a dyno and see, it could be quite entertaining if it puts down a big number and upsets a few guys on the Fiero Forums...
                  it's worth mentioning that this exhaust was probably as much or more work than a set of headers, parts of it may have been cheaper, but it still wasn't for the faint of heart.
                  • dbral
                    • Feb 2021
                    • 38
                    #24
                    Personally think that it turned out great and was well worth the effort. Seeing the two pipes merging that way in a couple of photos and automatically thought that you were going to run dual exhaust!
                    • ericjon262
                      build it.
                      • Jan 2010
                      • 2218
                      #25
                      I originally planned on running a dual exhaust, but I got tired of working on the car, and then scrapped the idea.
                      • dbral
                        • Feb 2021
                        • 38
                        #26
                        What did you have in mind for the routing?
                        • ericjon262
                          build it.
                          • Jan 2010
                          • 2218
                          #27
                          I was planning to route it along the stock path, just doubled.
                          • young gun
                            • Jul 2010
                            • 250
                            #28
                            Almost a glutton for punishment!
