94 camaro 3.4
  • Tjjensen24
    • Jan 2025
    • 2
    94 camaro 3.4
    Can anyone help me understand how to adjust the pushrods I am changing the head gaskets and can't find any info on it
    • 13534
    Adjust valves when lifter is on base circle of camshaft lobe. Tighten adjusting nut until there is zero lash + one turn. This can be determined by rotating pushrod while turning adjusting nut. When lash has been removed, turn adjusting nut one (1) additional turns (to center lifter plunger).
    • Tjjensen24
      • Jan 2025
      • 2
      Ok so zero lash would be when the up and down movement is gone correct
        • 13534
        Correct, pushrod should spin on its axis but no side to side movement. Easier to determine that way rather than up and down motions. Then 1 full turn.
