Ultimate GenIII 660 (3X00) swap reference
  • DarkKnight
    • 53
    Got this from http://www.v6z24.com.
    Thanks to Chris R., Chris W., Colin B., and Scott T., for creating such a great site.
    P.S. I vote to make this a Sticky!![/url]
    • 13466
    I added the link onto the site under engine swaps. I don't like making stickies since the site is the permanent (well ok, we like to think it is) source for information and links.
    • ikessky
      • 614
      Oh come on Ben. You're just bias to the site.
        • 13466
        Yeah, there are no J body sites...they don't exist. There are no other sites that even make mention of the 60V6 engines...they are just your imagination. hahaha, oh boy.
        • GPXSS
          • 588
          that site should be called www.jbodycrew.com
          :P
          I modify stuff
          • v6h.o.
            • 1418
            LOL!
            Colin
            • Guest
              There will be more than just J-body info on there, soon enough.
              Sappy: Thanks for adding the site to the links,
              • GPXSS
                • 588
                so Colin... that thing running with the Gen3 top end? Did you get it tuned right?
                Wont be long before i get back to working on my GP and need some people to bounce idea's n stuff off of
                I modify stuff
                • v6h.o.
                  • 1418
                  its not running right now. been parked for the last 3 weeks due to the snow on the ground.
                  i had a Fastchip stage 2 in there that i bought about 3 years ago... while on the dyno i noticed strange happenings... the a/f ratio was all good under load, around a good 12:1 ratio, then as the rpm kept climbing the a/f dipped even lower and lower and lower... untill about 5000rpm at which point it started going back towards 12:1 range ??
                  so i went back to the stock chip for now. watching on the a/f gauge the stocker doesnt do this stays flat and true with the a/f ratio. the fast chip does? POS chip. i need to get ben or someone to burn me a chip one of these days.
                  did you get those headers modified yet to fit yet?
                  Colin
                  • GPXSS
                    • 588
                    nope, they are sitting in the S&S box and have been since the last meet. I just got the new radiator put in the Fiero, so once im sure its running right ill finally pull the GP in the garage and get to work on it.
                    I guess you won't have quite the same problems as me since you are still using a 3.1 bottom end and cam, but you will still need more fuel all over with the Gen3 top end. Are you running a 62mm TB?
                    I modify stuff
                    • v6h.o.
                      • 1418
                      no im running a bored over 2.3L quad 4 throttle body. i took mine out to 60mm.
                      yeah i gotta get a chip soon. the only mod to the fuel system is the caspers ADJ FPR. that and the autometer a/f gauge to try and "tune" the regulator for proper fuel ratio. i find mine with stock chip is decent around 45-50 PSI idle.
                      Colin
                      • JohnyG
                        • 32
                        Next test&tune try my FFP chip tuned for the 3400. Im curious to see if it will make a difference.
                        -John
                        14.9 @ 93.7MPH
                        -Bonestock 3.4L
                        -Bully Stage 2
                        -2.5\" Exhaust
                        -WAI
