LS1 springs
  • StudlyCamaro
    • Nov 2003
    • 692
    LS1 springs
    i know i read on the old site that someone had their heads moddified to use an LS1 valve spring, anyone know how this was done?
    -Aaron
    3.4L camaro some goodies
  • robby1870
    Squaddoosh
    • 584
    V6h.0. has it done, IIRC
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
      • 9186
      GPXSS has done it as well...
      IIRC, stock is on the left and the LS1 is on the right. He has a spreadsheet on what parts are needed as well, I just need to find it.
      • GPXSS
        • 588
        no head modifications necessary, the above picture is using a Compcam LS1 beehive spring, the smaller value of the 2 they offer. You have to use stock GM LS1 spring seats and use the rest of the stock 3100 spring hardware up top. You aslo have to use older style 3.1 stem seals.
        I modify stuff
        • v6h.o.
          • 1418
          yeah just like GPXSS said.
          i used:
          stock GM LS1 Springs,
          LS1 retainers, LS1 Locks. and LS1 brass spring seat shim's due to you need something between the aluminum head and the spring to keep from ruining the head.
          also stock 3100/3400 vavle seals as gpxss said will not work. the springs are too narrow to fit around them. i use stock 3.1L Vin T valve seals.
          im wanting to upgrade this year to either Comp or Crowers new LS1 replacement Titanium Locks and Retainers
          mmm... less weight...
          Colin
          • v6h.o.
            • 1418
            my springs... the only pic i have of them unfortunatly.
            Colin
            • StudlyCamaro
              • Nov 2003
              • 692
              sweet, you guys are very helpful , thanks a lot
              • jweir22
                • 111
                What is the benefit of the LS1 springs compared to stock?
                1995 Cutlass Supreme 3100 SFI
                Cold Air K&N Filter
                58mm TB
                Dynomax Duel Exhaust with Performance Catalytic Converter
                FFP Underdrive Crank Pulley
                1/4 mile 15.65 at 90.8 mph
                • StudlyCamaro
                  • Nov 2003
                  • 692
                  they are stiffer, thus allowing me to use a higher lift cam in my car
                  • GPXSS
                    • 588
                    The retainer use on the right in that picture is the Comp Titanium retainer.
                    I was thinking of getting them, but there are 2 reasons why I didnt:
                    1. bling bling
                    2. the weight savings isnt all that drastic over the stock retainer.. you get more of a savings by going to SI valves.
                    I bought 2 retainers from Comp.. the LS1 Steel and LS1 Ti .. the Steel one is heavier than the stock 3100 retainer, and the Ti is maybe 3/4 the weight of the stock 3100 retainer.
                    In hind sight.. im betting if you use Ti retainers, Ti locks, and Si or other lightweight valves, you can run stock 3100 springs on a high lift cam with no problems N/A.
                    I modify stuff
                    • v6h.o.
                      • 1418
                      thanks for the heads up GPXSS, how much lighter are the SI valves than stock, i take it you weighed them.
                      ive been meaning to upgrade the vavles as well for a long time, just havnt got around to it.
                      someday. when i get fundage again.....
                      Colin
                      • robby1870
                        Squaddoosh
                        • 584
                        So Colin, did you have to do anything to the heads to make the LS1 springs fit?
                        Robby Whitesell
                        2006 Pontiac G6 GT
                        • v6h.o.
                          • 1418
                          other than using the lower brass spring seats/shims and using the older MPFI 3.1L style Valve Stem Seals. no not really.
                          by the looks of things as GPXSS has shown, stock retainer/lock hardware works with these springs, but in my case i used the full LS1 spring setup,
                          i work at a dealer eh, so parts are cheap, so this is why i went this route instead of aftermarket comp/crane ect springs.
                          the other plus advantage to teh LS1 springs is the shape of them, they use like the 3X00's use a Conical/Beehive shape. which reduces spring weight and mass and makes for a lighter spring...
                          and with most instances in valvetrain lighter is better.
                          Colin
                          • robby1870
                            Squaddoosh
                            • 584
                            Cool, since Im building a 3.1L this might be something I look into. Whats the coil bind height of the LS1 springs? Stock 3.1L is like .500", IIRC. Just wondering on the LS1s if they can take more lift
                            Robby Whitesell
                            2006 Pontiac G6 GT
                            • StudlyCamaro
                              • Nov 2003
                              • 692
                              LS1's .510 , LS6's .560
