LS1 springs
  • chvyrulz350
    • 11
    im just curious but youknow how you can use the crane cam narrow roller rocker i think
    can they be used on the aluminum heads or is there not enough room
    also why did you use the ls1 springs i thought that sbc springs fit
    • chvyrulz350
      • 11
      o and gpxss you used bling bling in the wrong context
      bling bling means jewelery and not money so you should have said mucho mojo
      maja bens
      or something along those line
      jfwy
      • robby1870
        Squaddoosh
        • 584
        Originally posted by StudlyCamaro
        LS1's .510 , LS6's .560
        Thanks!
        Robby Whitesell
        2006 Pontiac G6 GT
        1985 Toyota Pickup DLX
        • StudlyCamaro
          • Nov 2003
          • 692
          V6H.O.- what year/model was the vin "t" from? , also what type of rocker arms are thoes?
          3.4L camaro some goodies
          • robby1870
            Squaddoosh
            • 584
            Those are Comp Cams Magnum Roller Tip rockers. Im guessin he has the 1.6s. I used to have them on mine, they are a nice addition. Im trying to put them on teh motor Im building with the crane 272
            Robby Whitesell
            2006 Pontiac G6 GT
            • jweir22
              • 111
              #21
              Yea they are nice rockers but arn't they really expensive for just a roller tip gain from your stock 1.6 roller fulcrum rockers?
              1995 Cutlass Supreme 3100 SFI
              Cold Air K&N Filter
              58mm TB
              Dynomax Duel Exhaust with Performance Catalytic Converter
              FFP Underdrive Crank Pulley
              1/4 mile 15.65 at 90.8 mph
              • robby1870
                Squaddoosh
                • 584
                #22
                well yeah, if you have the 1.6 rollers already they arent worht it, but if you have stamped steel 1.5 rockers like I did, they are worth it
                Robby Whitesell
                2006 Pontiac G6 GT
                • StudlyCamaro
                  • Nov 2003
                  • 692
                  #23
                  i keep forgeting that not all of the alumnium heads had the 1.6 roller flucrum rocker arms.. (mine do)
                  • v6h.o.
                    • 1418
                    #24
                    3.1L vin T engines are the regular run of the mill 3.1L mpfi, used in Jbodies, L bodies, W bodies,
                    89-94 are the years for them IIRC.
                    those are a set of Comp Cams Magnum Roller Tip Rockers.
                    those ones in the pic i think are my old 1.52:1 rockers. right after that pic i swapped out and went to a set of 1.6:1 roller tip's.
                    my 3.1L started out as a regular old 92 3.1LvinT, then i upgraded the valvetrain in it..... Comp Cam cam/Rockers/lifters, and the LS1 springs,
                    the old Gen2 engines never used roller rockers, they were shit stamped steel crap. thus the upgrade of the roller tips. (much cheaper than crane gold extruded full rollers..)
                    then later on, i upgraded to the full 3X00 top end on the old block. didnt use the 1.6:1 stock roller rockers because at the time i didnt want to order custom pushrods to make them work... (non roller cam, with the 1.6:1 GM rockers requires a custom lenth pushrod) i should have done it that way though. ah well hindsight is 20/20. that and now that i own a pushrod lenth tool it makes it heaps easier... maybe next engine i'll do them like that.
                    i run a valve lift of .469 now with those springs
                    Colin
                    • Pinoy
                      • 2
                      #25
                      i had just OEM LS-1 valve springs put on my 3400 heads. the guy that did all the machine work on them does work on race cars, and he said i wouldnt need anything else to have them work, everything apparently worked and fit properly.
                      Grand Visions North
                      Racer X Motorsports
                      • AaronGTR
                        boost lover
                        • Jan 2004
                        • 708
                        #26
                        OK, so after reading all this let me see if I got this right. If I want to put LS1 valve springs on a 3400 head all I need is a different valve stem seal? Anyone have a part number. My dad works at a dealership so I can get parts cheap. I already have a complete set of LS1 springs, shims, and retainers. Also wondered if anyone knows how much the titanium LS1 retainers cost?
                        '97 Grand Prix GT 3800 (sold)
                        Gotta love boost!
                        • v6h.o.
                          • 1418
                          #27
                          yes. if you already have: retainers, locks, spring shims, and springs from the LS1 engine.
                          all you need is just a set of 3.1L VIN"T" valve seals..
                          (as the stock 3X00's seals dont fit inside the spring.)
                          Colin
                          • AaronGTR
                            boost lover
                            • Jan 2004
                            • 708
                            #28
                            Ah, I see what you're saying now. I just went out and test fitted the spring and the stock seal and shim is one piece and the LS1 spring won't fit over it. I'll see if my dad can order me some of those T seals. I assume since you refered to them as 3.1L VIN"T" they are from the old iron head 3.1L engine and not the 3100 right? Thanks a lot for the info.
                            Oh yeah, in case anyone wanted clarification. I noticed the stock retainers and the LS1 retainers are the same diameter and either one will fit. The LS1 retainers are slightly thicker and heavier though and probably a better choice. Both use the same locks.
                            Gotta love boost!
                            • v6h.o.
                              • 1418
                              #29
                              no the old 3.1L GEN2 engine, the 3.1L MPFI aluminum Head engine from the FWD GM vehicles.
                              Colin
                              • AaronGTR
                                boost lover
                                • Jan 2004
                                • 708
                                #30
                                What year/model car would it have been in?
                                Gotta love boost!
