Stud Girdle
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Stud Girdle
    Before I make my on does anyone know of an avalible stud girdle for the old iron heads? If it is not to expensive I'll buy one. Otherwise I am gonna make one when I go back to school. Just for a fun project.
  • StudlyCamaro
    • Nov 2003
    • 692
    RE: Stud Girdle
    i was under the impression that there were never any made... make your own it'd be fun
    3.4L camaro some goodies
    • geoffinbc
      • 5831
      Alright I guess I will.
      • chevyman350
        • Nov 2003
        • 23
        yes, There is a company that makes a stud girdle for the old iron heads, look in the PAW catalog. I have seen them but i don't have my coppy with me.
        • geoffinbc
          • 5831
          I could not find anything on PAW camshafts
            • 13525
            Well, thats one of the things I wanted to have made for the store since its something we could use and its not made that I am aware of. Actually, I do remember seeing something but it might have been an oil scraper (another thing I want to have made available). So yeah, I guess we just need to get a design down that is solid and bolts right up. Hell, couldn't you then make it able to use either oil pan? I am thinking like the 420A mitsubishi motor I messed with a while back for a friend. The mains were all one piece. Perhaps some block modifications will be required to make this work, im not sure.
            • geoffinbc
              • 5831
              I ment head studs. For the rocker arms
              But mains would be cool too.
                • 13525
                Ah, so like shaft rockers or what? Never really heard of a girdle for the rocker arms themselves.
                • geoffinbc
                  • 5831
                  Stud girdle sometime called valvetrain stabilizer
                  • StudlyCamaro
                    • Nov 2003
                    • 692
                    i was thinking for the main caps as well.. ive never even heard of a valve train stabilizer before (puts tail between legs)
                    • AaronGTR
                      boost lover
                      • Jan 2004
                      • 708
                      Me neither... betterthanyou stumps me again.
                      That why I love this site though... lots of cool technical discussions going on. So what are these supposed to do for your valve train? Pros and cons?
                      '97 Grand Prix GT 3800 (sold)
                      Gotta love boost!
                        • 13525
                        Thats pretty wild. Does it have anything to do with thermal expansion and torque loads on the rocker arm bolts? I wasn't aware of any flex in the stock setup but I guess if you want to make everything as solid as possible this is the way to go. Don't see it working on the splayed valve setup very well though:P
                        • geoffinbc
                          • 5831
                          It only works for studs. You install a special lock nut that has a coller comming off the top. The collar is then gripped by the stabilizer on all the studs at the tops adding strength and stability. The ones pictured above are for an BBC and thats why they are all offset. Ones for smallblocks and the old iron heads would be inline
                            • 9190
                            But as Ben stated, how feasible would it be to try to make one for splayed valve heads? You'd have to take a pretty big chunk of aluminum and slap it on a 3 or 5-axis CNC machine to a single peice of material to go across all of the rockers. Just doesn't seem to be something worth the hassle.
                            • geoffinbc
                              • 5831
                              Who cares about you Gen III guys LOL... Inline valve heads would be a snap
