Part Compatibility on my topend rebuild?? ::UPDATED::
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    I just want to make sure everything i'm putting together here will work together. and or if i'm missing anything.
    What I currently have:
    I have 2000+ 3100 P&P RSM intakes
    62mm RSM TB
    2000+ 3400 heads (to be P&P/resurfaced on may 1st) i am getting the funds on the 1st from a relative!
    Custom Grinded Cam. #1461-- 206/212, .282/.292 lift @112
    LS2 valve springs
    chysler 318 valve seales
    sivalves SEV-01811(8mm) 4.736"
    SEV-01929 (8mm) 4.684
    egr adapter
    Intake Gaskets
    Spring seat
    Timing chain kit
    To be purchased this weekend and or the weekend after:
    Head Gasket
    Plenum and head bolts
    ROCKERS??
    Am I missing anything here?? What else can I do to make this car more powerful while i'm in there.
    Corey M.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    That cam will get the car into 6500 RPM with the port work no sweat. I wouldn't replace the retainers and locks not necessary. Just get the stock gaskets. Thats all there really is
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      keep the current retainers and locks in there???
      • jeremy96gase
        • 93
        The engine might rev to 6500, but a stock 4t60-e is gonna crap out real quick doing that a lot.
        • geoffinbc
          • 5831
          Yea. Unless they look hammered out. But these heads are new 3400 stuff right? So they will be fine.
          • blackbombshell95
            Kaiō-ken X 10
            • Jun 2004
            • 1386
            i have 3400 heads.... am I missing anything here? what do I do for rockers? I don't think i want to use my old ones.
            Now the valves that I listed above. They don't need a valve job since tehy are new?? or is there a way to improve them? And how about the length of them? Will that affect anything, since they are not stock size.
            • geoffinbc
              • 5831
              If the stem is not stock length then that is going to change alot of things. You will need an adjustable valvetrain and will need custom pushrods, well maybe a stock size one but it will have to be ordered. So get an adjustable pushrod cecker to veryif geometry then you can order rods.
              Are they shorter or longer now?
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                I just purchased the valve seals and valves from SIvalves. $10 a pop X 12. I'm stoked.
                Now i need isky to chime in about those spring seats.
                INJECTORS: now the newer style 3100/3400 used the same size injectors if i'm understanding this correctly. Are they at all bigger then the old style 3100 injectors? What size would that be. And would my stock computer run them well?
                • blackbombshell95
                  Kaiō-ken X 10
                  • Jun 2004
                  • 1386
                  TTT
                  • geoffinbc
                    • 5831
                    I think 3X00 injectors have a different impedance and most likely also have a different flow rate. I would not use them I would stick with the ones your ECM runs now.
                    • blackbombshell95
                      Kaiō-ken X 10
                      • Jun 2004
                      • 1386
                      What options do i have for ROCKERS.
                      • geoffinbc
                        • 5831
                        Stock rollers or Crane Gold Race. Or pick any SBC narrow body rockers and an ARP stud kit. You may have to clearance the intake depending on what you go with
                        • blackbombshell95
                          Kaiō-ken X 10
                          • Jun 2004
                          • 1386
                          what combination would you recommend for the best performance with watching the price?
                          Would you absolutely recommend the arp stud kit? Is it because of a clearance issue that this kit is recommeded? I would like to go with what is cheaper. If you highly recommend it then I will get the kit.
                          I would like a set of rockers that are better than stock. Without going crazy with the $$.
                          Once again, with your experience, what would you recommend?
                          • geoffinbc
                            • 5831
                            You must use the ARP studs becaue you need to convert the 10mm threads in the head to 3/8 top which is on every SBC rocker. The Crane gold race kit is really nice. But just shop around for different rockers. Crane Energizer or comp rockers are cheeper.
                            • blackbombshell95
                              Kaiō-ken X 10
                              • Jun 2004
                              • 1386
                              You wouldn't happen to have a part # or even better yet a link to the crane gold race kit. I did a search on the web i have no clue which one is for my car.
                              I just noticed that you are in B.C. I should stop by, i'm going there in may :P
