Part Compatibility on my topend rebuild?? ::UPDATED::
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    #31
    Do you have trouble with it dying?? and do you still have it installed?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
      • 9190
      #32
      It wouldn't run on its own for the first 2 minutes or so. After that, it was just a really lopey idle. No, its no longer installed, only because I swapped a 3400 into the car. CNCGuy has the cam though and will be installing it in one of his engines.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        #33
        Head work dont mean shit. It is not going to make the cam work any better. The problem comes with the large duration and narrow LSA. This means lots of overlap and in turn poor scavenging of the cylinders at idle along with low vacuum. The PCM will not like this. It is possible to get the PCM reprogrammed to work with the lower vacuum. But the idle will still be lopy. However the cam will be very powerful in the top end.
        Me personally I would like to see an LSA of 112 instead. Oh and if you ever plan on boost that is a VERY bad cam. If it had an LSA if 114 to 116 it would be good for boost.
        • blackbombshell95
          Kaiō-ken X 10
          • Jun 2004
          • 1386
          #34
          Boost is for sure. oh man. I really wanted that cam lol. hmm. I guess i should stick with the mild regrind that i have.
