91 3.1 Port work
  • Dave
    • Nov 2003
    • 222
    91 3.1 Port work
    So some people were talkin' about portin' the heads in an other thread, but I'm wonderin' somethin' a little different...
    I'm new here, tried a search, probably not lookin' for the right things..
    I've got a 91 Beretta GT with the 3.1, I'm gonna be doin' the head gaskets, but was wondering, should I go with the newer year heads (3100/3400) or should I just do the portwork to the heads I have - Tryin' to figure out what would be more cost effective - I can actually get onto a flowbench for almost nothing, so I'm thinking if I port the ones I've got I should be a little better off.
    any hints or tricks? I was thinking about takin' the head down enough to raise the compression up an other point and modifying the head to accept adjustable rockers. any help would be great!
    --Dave
    1991 Beretta GT (3.1 - 3T40)
    1988 Regal Custom (2.8 - 4T60)
    Dave ... Dave.45 ... DaveFromColorado ... it\'s all me.
  • akira
    • 45
    The 3400 heads flow way better but... "These genIII cylinder heads are used on late model V6/60 degree engines for improved performance. They feature an increase of 0.040" in intake valve diameter and a reshaped port for a flow improvement if 16.7% at 0.450" of valve lift. The exhaust port has been reshaped into a "D" port configuration for a flow improvement of 31.7% at 0.450" of valve lift." That is a quote from the gm peformance catalog. But you need the 2 peice intake for it as well. Alot of people here have done the swap.
    Why pay someone to do the work, it costs alot and you don\'t learn s*^t!!!
    • v6h.o.
      • 1418
      the main gains from using the GEN3 heads on a 3.1L mpfiGen2, isnt just the heads. its the intake manifolds used on the GEN3 engines that bolt to the heads. the main restriction even with a good set of ported heads on the 3.1L mpfi is the upper and lower intake manifolds. they're piss poor.
      Colin
      • GRANDFURY
        • 51
        so will the upper and lower intakes bolt right up to the 3.1 ? and if so then you could mount the heads right?
          • 13531
          nope, you need the heads to make it an easy swap. The amount of work to make gen 3 work on gen 2 is pretty extreme for port matching.
