Most a 3400 has been bored over?
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    Anyone know what the most a 3400 can be bored over safely? For a N/A setup.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    1.50mm, or .060" over i think. it shoud be the same for all the 60* blocks exept fot bowties and prototypes.
      • 9190
      Sadly, boring a 3400 even 0.060" over brings it to just over 3400cc, since it initially starts out around 3350ish.
      • blackbombshell95
        Kaiō-ken X 10
        • Jun 2004
        • 1386
        oh that sucks. so .060 wouldn't be even close to being a 3.5
        • project60degree
          • May 2005
          • 85
          this might be a stupid question but if 3100 and 3400 are the same block, to make a 3100 a 3400 it would have to be bored .120 over so technically couldnt a 3100 be bored .180 over of a 3400 can be bored .060 over???or am i just way off about that?
          • RidgeRunner
            • 971
            But they're not quite the same block.
            60v6's original Jon M.
            • v6h.o.
              • 1418
              They don't share the same block.
              Colin
              • project60degree
                • May 2005
                • 85
                whats the diff???
                • RacerX11
                  • 1060
                  The 3400 block is cast with larger cylinder bores.
                  '99 Z-28 - Weekend Driver
                  '84 X-11 - Time and Money Pit
                  Quote of the week:
                  Originally posted by Aaron
                  • sharkey
                    • Jun 2004
                    • 2061
                    look at it this way, the 3100 block is like a 3.1l gen 2 block, and the 3400 is like a 3.4l f-body block.
                    • project60degree
                      • May 2005
                      • 85
                      ok thanks...this is a little off the subject but are the RWD and FWD blocks the same b/c....would a THM200 from a 80's firebird work on a gen3 3100???
                      • 1QUICKHATCH
                        • 387
                        the starter on the rwd blocks are on the right/ passanger side of the block, and the fwd blocks have the starter on the driver/front/left side of the block. One or both of the dowel pins in the back of the block for the transmission are in a different location too I beleave. not sure if all the thm200's got the aluminum torque converter covers but you would have to modify that for starter clearance too if you bolt it too a gen III block.
                        14.96@91.47 in the 1/4
                        9.63@74.36 in the 1/8th
                        • MidnightriderZ24
                          • Jan 2005
                          • 699
                          i think mev from JBP bored 1 over to 3.8l. i remember seeing a post on v6z24.com a year ago saying that.
                          [SIGPIC]
                          12.268@117... 11's to come!
                          • RidgeRunner
                            • 971
                            To just bore a 3400 to 3.8L, you'd need about 5.5mm overbore (.216in) giving you 3763cc (rounds to 3.8L).
                              • 9190
                              They use their crank to get 3.8L, not the bore.
