Experience with anti pump-up lifters?
  • ssdurango
    • Dec 2004
    • 170
    Has anyone swithched to anti pumpup lifters? Is it worth the money? If so, who makes them?
    SSDURANGO:
    89 S-10, 3.4, 11:1, 252 Comp Cam, 1.6 Roller Rockers, SI Valves, ported, 4.3 TBI, headman headers, 3 " Flowmaster Exhaust .
  • sharkey
    • Jun 2004
    • 2061
    RE: Experience with anti pump-up lifters?
    when you are doing a performance build up, or even just a cam swap, its worth the money to put in good lifters. the ones in my motor are comp cams, crane also makes them.
    • ssdurango
      • Dec 2004
      • 170
      Which lifters did you buy? I bought the "high energy" ones. They don't seem to be anti pump up lifters. I don't see any anti pump up lifters on comp's website for the 60 v6.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        No they probabally dont make them. But like I said you wont want them unless you are truly running a race engine that will normally operate above 5000.
        High Energy lifters are great street lifters.
        • TurboGTU
          • 453
          Its either hydrolic or solid type. GM power manual recomends piddle valve lifters. Seal power PN# AT-992. Pure solid lifters are not recommended due to it leaking on the pushrod seat.
          I'm not a fan of anti pump ups due to having different leak down rates down the stretch and some not pumping up when they should.
          • blackbombshell95
            Kaiō-ken X 10
            • Jun 2004
            • 1386
            bty what would u recommend for my setup that i'm doing? for lifters.
            02 GTP - 90* > Failboat
            www.blackbombshell95.com
              • 13520
              has anyone looking into overboring the lifter bores and using LS1 lifters? I have no idea if its possible but you know the LS1 has an aftermarket.
              • TurboGTU
                • 453
                I don't see why we can't mod our "current" lifters. Seen some aftermaket lifters with a Pin hole in the bottome center to oil the cam lobe. Looks better than our "sometimes I oil the cam..sometimes I don't" slot. I've seen them just loading the sping where it has .01 to go and machen a new locking clip there so it would be a sub hydrolic lifter..but only pumps up for that .005-.01. Or just take out the check ball and keep the spring in there.
                I would think it would be kinda ifffy to bore out our lifter bores as there little space between them. Care to be the first?
                  • 13520
                  Probably not if they are too close. I don't know though, its been a while since I starred at lifter bored in the block.
                  • geoffinbc
                    • 5831
                    Just run a lifter from Comp Crane or GM. All will do an excellent job. By changine fromone brand to another you wont notice any difference. But don't run a fast bleed or anything like that
                    • your_I.D.
                      • Mar 2005
                      • 337
                      Rhodes lifter will modify any hydralic lifter. (if it can be dissassenbled) To act just like a regular Rhodes lifter. Set of 24 lifters for the DOHC motor was $125.00+ shipping. So I'd imagine 12 would be around $70.00+ shipping. With a week turn around time.
                      1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
                        • 13520
                        I wonder how that would work out with my 48 gram lifters. Very interesting Did you notice any difference?
                        • EspanolaGuitarista
                          Visionary
                          • Feb 2004
                          • 254
                          If you can modify...
                          a rhodes lifter then wouldn't it be possible to run a 220° cam and smog it too? (By the way the degree sign is alt+248.) I read they decrease duration by 10° at low rpm.
                          • your_I.D.
                            • Mar 2005
                            • 337
                            I haven't tried it on the 3.4DOHC. I have run them in a radical SB chevy that wouldn't idle in drive with stock lifters. Changed over to a set of Rhodes lifters. Vacuum at idle went up and would idle in drive. Made it very streetable as a daily driver.
                            • torq455
                              If I only had money!!!
                              • 1615
                              i had rhodes lifters in my 66 GTO. they helped, but the side affect was a little noisy when warm at low rpm. still, maybe worth it if you have a big cam.
                              Andy
                              fastest 1/8: 10.19@ 67.17
                              fastest 1/4: 16.16@ 82.70
