Recommended # injector/fuel pump for my app?
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    Like the topic says, i'm looking for right # injector for my setup. And for the right fuel pump. I'd imagine the dyno tuning place would be the best place to ask. But I think i can get a good idea of what I might need if i ask here. I want to try to eliminate a fuel problem. I don't want to run too lean.
    Some of u know what I'm doing. But not all of you.
    Just for a recap of what i'm doing. Here it goes
    95 grand prix. swapping a full 3400. obd 1.0 91-93 dohc pcm swap. Heads,lim,uim, and TB P&P. Very aggressive CAM. No specs yet. Crane gold series 1.6 roller rockers. S&S headers. 75 shot of nitrous zex. full bottom end rebuild with forged pistons. molly rings. shot peening the rods. Plus much more. 2.5'' cat back exhaust. All of these things I have currently done except for the heads and bottom end rebuild. Heads are at Ben's place. As soon as the heads get in i'm getting the bottom end rebuilt. plus a few more things which I can't think on the top of my head.
    Would my stock 3100 fuel pump be fine? should I put a differnet fuel pump? stock 3400 injectors fine? or larger injectors?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
  • RacerX11
    • 1060
    RE: Recommended # injector/fuel pump for my app?
    Pump: http://store.summitracing.com/defaul...4&autoview=sku
    Injectors: http://store.summitracing.com/defaul...1&autoview=sku
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
      • 13531
      Thats just retarded. How in the fuck are you going to tune 98 pound injectors for an NA 3400 using OBD1.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        FLOOD :P
        Run stock injectors with a wet kit.
        • blackbombshell95
          Kaiō-ken X 10
          • Jun 2004
          • 1386
          I almost died when I read that. ROFL.
          ty BTY.
          FUEL PUMP? I know zex makes a fuel resevoir between the tank and the injectors just incase the pump and get enough fuel.
          Here is a link.
          • eliteweapons
            • Apr 2005
            • 185
            he must own a gas station. lol
            95 Beretta Z-26
            • TurboGTU
              • 453
              I've seen larger injectors "work" with fuel pressure ajusments and driver (FET) upgrades.
              30-45lbs injectors should be plenty.
              YOu know dam well your pump is a weak suck. A walbro 255 HP pump should be plenty. Or something similar in flow and pressure.
              I don't know how the 3*00 fuel rail is...but on my MPFI fuel rail, I had to port out the fuel feed pipes that feed the fuel rails from the fuel pressure regulator.
