idea for crank under drive pully
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    well im not thinkin this is ground breakin news or anything, and its prolly not even that good of an idea lol
    but what about taking a stock crank pully and then heat that bitch up with a torch and seperate the v-grooved outter section from the inner section
    get that rubber damper outta there
    and take it to a machine shop and have them lathe mock the v-grooves into that piece
    anyone ever take one apart, is it smooth or not a good surface to do this too
    i realize that a turn off would be the loss of harmonic balancing, but you could get the pully balance
    i wonder what this would cost, maybe its worth lookign into compared to buying an expensive aftermarket one ?
    • 13514
    RE: idea for crank under drive pully
    Id rather have the FFP one as its machined properly already and is lighter. The only way id go with a different setup is if its an underdrive that retains the rubber damper.
    • sil
      4T60-E killa
      • Nov 2004
      • 723
      i wish i had a cnc machine
        • 13514
        I wish I had a dyno:P
        • TurboGTU
          • 453
          Why not make the other pullies underdrive.?? The alternator and the PS pump would be the HP robbing culprits. The A/C doen't rob power in WOT...only in cruse/part trottle if its on. Don't touch the watter pump.
          Your bearings and crank will thank you for it.
