port theory question
  • spacecadetz26
    • Nov 2004
    • 119
    I used those carbide burr bits when I ported my 2.4 head, they sure do work fast. I dont have the control and paitence to get my work looking that good. Thats awesome stuff there.
    Stephanie
    92 GTZ ~SupermoddedW41GTZ~
    • Guest
      Re: RE: here
      Originally posted by Arns85GT
      And that is why Pennock booted you off.
      Sorry if the truth hurts but those pics did suck and so did your port work from what I could tell from the out of focus and low light pics.
      The McCrays are a port job as well as 614streets. Not what you did.
      you brake out of the 15's yet with your new 2.8 and "ported heads" and hi flowing carb intake? Bwahahaha
      • v6h.o.
        • 1418
        Oh hell yeah. its amazing how quick you can burn through alum with those things.
        I've done a heap of 2.4L heads too. I should have pics somewhere? of the ones I've done.
        Thanks.
        Colin
        • TurboGTU
          • 453
          you all won't know a good way to clean duble cut burros loaded with alumi..LOL. Pops did a grind down on a watter pump.
            • 13534
            WD-40. Then grind on something you don't care about for a second. I use ginders grease from eastwoodco.com, but have heard many people use a bucket of WD-40 to dip the cutters in as they start to get clogged.
            • v6h.o.
              • 1418
              #21
              Damn I was just going to say the same thing! I use GM penetrating Fluid (wd-40 type fluid) works like a charm for keeping them unplugged.
              I even find Ben that just spraying the wd40 on and going back to cutting most of the time takes it out, Otherwise I just give the carbide a quick touch while in use to a piece of steel and it shakes them loose.
              Colin
              • farmerz24
                • Feb 2004
                • 361
                #22
                colin, ill get a bunch of pics this weekend so you can show your work. cant wait to install it along with milzy stage 1 tarbo cam and see what it does. this is a 3100 with 3400 intakes and large valve heads (in my 00 3rd gen cavy 5spd).
                and maybe even next spring the first 3rd gen turbo 60deg6.
                BOO YA.
                  • 13534
                  #23
                  3rd gen j body I take it.
                  • farmerz24
                    • Feb 2004
                    • 361
                    #24
                    yes third gen cav.
