Head flow numbers.
  • Guest
    Head flow numbers.
    Yeah, yreah I know... "search", well I did.
    I thought I had found what I was looking for when I came accross this in a thread:
    http://60degreev6.com/GPXSS/flowdata.html
    Unfortunatly, the "page cannot be displayed"
    So does anyone have the information that was contained on that page?
    I'm specifically looking for the 3100 and 3400 flow numbers, small and large port. genII would also be fun to have.
    TIA
    EDIT: I found the page: http://60degreev6.com/GPXSS/docs/flowdata.html
    But it doesn't have 3400 flow data.
    Does anyone have the 3400 head flow data?
    Does anyone know what year 3100 GPXSS used?
    Also does anyone know what pressure drop was used?
    I'm entering this data in DD2K and would like to be as accurate as possible
    TIA
  • donk_316
    • Mar 2004
    • 427
    goto the download section and fire up the DD2000 files in there.
    1984 Indy Fiero 3.4L
    13.7 sec @ 98 mph
    *ALL THROTTLE AND NO BOTTLE*
    • Doward
      • 127
      Anyone have any info on the iron heads?
      3.1L \'88 Camaro - 16G @ 9.5psi
      222/291 @ wheels
      T61 on the way!
      • Guest
        Ok, yeah I forgot about that section. But there seems to be a problem with the files.
        Take a look they come up as a text type document, but don't have any information that I could put into DD2K.
        Doward, if/when these files get working, there are a couple iron head files in the download section. Also, if you do a search there is a member that has iron head files, you could PM him. I found that while searching for head flow data, last night.
        • donk_316
          • Mar 2004
          • 427
          Nothing wrong with the files. Just change the file name extensions to what they are supposed to be.
          13.7 sec @ 98 mph
          • Guest
            Say what?
            Ok, when I click on "download this file" it opens up a page that looks like a text document, it doesn't "download", or even give me an option to do so.
            • Guest
              Just to show you what I get:
              This is for a 3400 stock cam:
              Originally posted by the download section
              3.10
              0
              Stock Street/Economy
              1
              Roller
              3
              0.050-Lift
              2
              1 0.000000
              1 0.437000
              1 0.437000
              0
              1 -14.000000
              1 30.000000
              1 30.000000
              1 -14.000000
              That is what shows in my browser.
              • donk_316
                • Mar 2004
                • 427
                Ok. Since your new to computers and all...
                Go to the page with the files "RIGHT CLICK SAVE AS"
                Dont just click it.
                Then when its saved it will look like this: filename.flw.txt
                Rename it to filename.flw (so just erase the .txt part)
                Then send me $59.95 + GST for the lesson and your done!
                13.7 sec @ 98 mph
                • Guest
                  Aight, I got it to work, didn't realize that I needed to right click, save as... I looked in that section to see if there was anything special that needed to be done, and no mention of that. Would be nice if it was at least mentioned.
                    • 13525
                    Yeah, it just displays the text in the document. I wish it would just think it was a file.
