Just what the subject says
Gen II was 88-94, yes?
What compression ratio were the Gen IIs?
88-94 iron heads still existed, and were diferent. i think 3.1 iron head motors were supposed to be 8.5:1, and im not sure about the 3.4'sIf you aren't friends with a liar, you aren't friends with anyone.
LOL, might be going something like that.... Gen III topend + Gen II rotating assembly + big arse turbo + '749 ecm?
I've started working on a LIM for it, too. LOL, THAT is going to be the fun part!3.1L \'88 Camaro - 16G @ 9.5psi
222/291 @ wheels
T61 on the way!
Do yourself a favour and go genIII pistons, I wish I had.Originally posted by DowardLOL, might be going something like that.... Gen III topend + Gen II rotating assembly + big arse turbo + '749 ecm?
Gives you 9.6:1 SCR (must use an .060" head gasket though, due to genIII pistons coming .020" proud of teh deck surface).
I'll be going to 9.3:1 with the .040" head gasket, when I put the new top end on.
Yes, I'll be switching to a 749 for my dizzy project, seems to be more support for the Sy/Ty .bin from enthusiasts, than the TGP code.
In all actuallity, thats just the advertized CR. from what i've read in other posts is there is as much as a 2cc difference in combustion chambers for the same type of head, or maybe even in the same head. so one car or even cylinder might have 8.9, and another 8.7 and yet 9.1, or perhaps even up to 9.8 on the newer ones. and then still the cc of the pistons dish, i'm sure there are variances everywhere. you'll have to figure out the cc's everywhere to get the truth about the CR for your specific car.If you aren't friends with a liar, you aren't friends with anyone.
Yes, advertised SCR is an average, just like the "1.5:1" stock GM rockers, which can vary from 1.32 to 1.64:1.Originally posted by Doubt_IncarnateIn all actuallity, thats just the advertized CR. from what i've read in other posts is there is as much as a 2cc difference in combustion chambers for the same type of head, or maybe even in the same head. so one car or even cylinder might have 8.9, and another 8.7 and yet 9.1, or perhaps even up to 9.8 on the newer ones. and then still the cc of the pistons dish, i'm sure there are variances everywhere. you'll have to figure out the cc's everywhere to get the truth about the CR for your specific car.
GEttigna dizzy to work with that gen 3 intake is going to be fun. good luck with that.Originally posted by The_Raven
D
I have already mocked it up. its not going to happen.
