IAT mod
  • project60degree
    • May 2005
    • 85
    IAT mod
    I know in the myths section it is explained y it is bad mod to do but what if you are pushing more air in along with the extra fuel?
  • SHOoff
    • Jul 2005
    • 356
    If you get enough airflow to warrant something of the sort, then you get enough of an ECU to adjust fuel without modding the IAT.
    97 Cavalier RS
    3400, Isuzu MK7
      • 13532
      Its fundamentally bad to screw with your sensors. Do I need to add something to that page to make it more obvious?
      • Rook
        • Jul 2005
        • 25
        lol, instead of modding to add more fuel...
        just crimp ur intake pipe to allow less air to get in...BAM! same affect as more fuel..right right
        - Rich - Hey Ya\'ll watch This
        Cardomain Garage - 5 vehicles...i have a problem
        Curren Daily: 1999 Silverado Z71, RCSB 5spd V8
        Project Vehicle:95 GrandAm, Dead 3100v6...plan 3400swap
        • project60degree
          • May 2005
          • 85
          WOW!!!! smart....no
          • SHOoff
            • Jul 2005
            • 356
            WOW!!!! smart....no
            'nuff said
            97 Cavalier RS
            3400, Isuzu MK7
            • Rook
              • Jul 2005
              • 25
              yay sarcasm.
              my friend has a 98 v6 mustang. and he was like "on ebay they have a chip for $20 that says it gives u like 20hp" and i told him....its not achip its just a resistor that goes into ur IAT sensor and tells the ECU the air is colder than it is...i told him its a .05cent resistor from radioshack...well he dint believe me...spent $20 on it...and got a piece of paper and a 5cent resistor attchaed to it.
              we intalled it...his MPG went from 20mpg to 11mpg, but he thought it was "WAY" faster....before his mustang he had a 94 cavalier with a HUGE spoiler on it and he said the spoiler made his 0-60 time a full second faster...so...yeeahh
              • tejohnson
                • 359
                FYI... The IAT has more of an impact on timing advance than fuel. But... The PCM may dump in more fuel to help quench KR from too much timing... (I suppose the later is debatable)
                Regards,
                Todd E. Johnson
                  • 13532
                  All it did for me was cause black smoke to come out the back every time I enabled the resistor.
                  • asylummotorsports
                    Banned
                    • Oct 2005
                    • 649
                    Originally posted by Rook
                    yay sarcasm.
                    Is there a part number for that spoiler? www.gmpartsdirect.com doesn't have a listing under Cavalier.
                    I could really use a second off my 0-60 times.
                    • Hemet8
                      • Aug 2005
                      • 144
                      In the words of Dr. Evil " RRRRRRRRiiiiiiiiiight"
                      Don\'t hate me because I\'m horny.
                      • tejohnson
                        • 359
                        http://www.gmpartsdirect.com/results...umber=12363940
                        That should give you *at least* another 30hp...
                        Regards,
                        Todd E. Johnson
                        • El_Diablo
                          STFUniversity
                          • 917
                          being leaner is better for power (and unfortunetly heat) production....
                          • tejohnson
                            • 359
                            And this thread comes back It did make me think of two things tho that is common in the GP community:
                            1) Happy Knob
                            2) ICCU
                            Both fool the IAT, but the ICCU goes even further and makes adjustments to the MAF signal too. Personally, I am not a fan of either, but, it can be helpfull for MINOR tweaking in the event you want to adjust the timing a Little.
                            Regards,
                            Todd E. Johnson
                            • Juglenaut
                              • 1130
                              If it were just that easy umph...yeah right
                              I you knew me awhile ago, I put PLC's on my Lumina in various locations running various instructions...long story.....
                              I am back
                              Mechanical/Service Technican
