Expected price to pay : valve job
  • Mars
    • Apr 2004
    • 826
    Hello all,
    Almost completed the DIY head porting listed on the site. I was just wondering what I should expect to pay for a valve job. I doubt a quality job can be done at home, correct?
  • Manitcor
    • 573
    RE: Expected price to pay : valve job
    when I have my heads surfaced I goto a local place that will do the angle lob for me as well, cost for both heads? $75
    i only do a 3 angle though
    1995 Monte Carlo LS
    3400 SFI 60v6
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      You should only do a 3 angle for street duty.
      • Mars
        • Apr 2004
        • 826
        Great, thanks!
        3 angle it is!
        • TurboGTU
          • 453
          Hope you buy new exhaust valves since they pit at the seat.
          • Mars
            • Apr 2004
            • 826
            I bet GM will have a field day on my *** for new valves...
              • 13496
              You can use SI valves but have an angle cut on the backside. They are 11.99 each I believe.
              • TurboGTU
                • 453
                what he said. Anything with more nicle content would help.
                • Mars
                  • Apr 2004
                  • 826
                  What do you mean by
                  I may end up getting these, the price is somewhat surprising...
                  Thanks!
                    • 13496
                    On the backside of the valve near the seat, there is a nice 1 angle cut with a large piece of real estate behind it just waiting to be mowed down. I would love to test different angles and see what can be done ultimately but at that price, research is slow:P I do know the SI valves hurt flow, and im guessing that 1 angle cut on the valve seat area is the culprit. You could possibly have a shop cut a few angles in there but I don't know what degree would be ideal.
                    • TurboSedan
                      • Jun 2004
                      • 218
                      i paid $191 for both heads (TGP heads).
                      that included hot tank/bead blast, new expansion plugs, slightly resurfaced, new valve seals (which i provided), and 3-angle valve job and assembly.
                      '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
                      '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
                      GM W-body Forums
