crane 272 cam with boost..
  • torq455
    If I only had money!!!
    • 1615
    #31
    oohhhhh!! how well does your car run. need details. any dynos or track times?
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    • Syn
      The Master Piece
      • Oct 2005
      • 599
      #32
      its snowing here right now in michigan so i am not taking it out until spring, i am getting my eprom custom burned in a few weeks when i get a damn reply
        • 13525
        #33
        Yes, I do port work. Ill have flow and velocity specs. I have a set of heads here that I will be modifying for boost as an experiment of flow over velocity on the intake side with boost in mind. The combustion chambers are also modified for lower compression (or stock compression using SI valves), as well as matched. The flow will also be matched when im done.
