Throttle Bodies
  • BillS
    • Oct 2005
    • 132
    Throttle Bodies
    One of the common mods to the V6 appears to be larger throttle bodies, whether they need it or not.
    With the 2.8, for example, I've seen flow bench date that indicates it makes no difference, other than lightening the owner's wallet by $200 and giving him bragging rights (at least not until you raise the engine to a much higher state of tune than the factory version).
    Question - does anyone know if the same holds true for the 3.4 cast iron head engines, which already have a larger throttle body - does hogging the TB out to say 62 mm. really have any effect - does a mildly cammed engine benefit from the theoratically increase flow capability, or is this just another exercise in wallet lightening.....?
  • 1QUICKHATCH
    • 387
    you may see some gains on a stock engine like better throttle response, but if you have some better engine mods like heads, cam the the TB will compliment them real nice! I did a set of heads for slowbird on here then we installed a 62mm TB after going to the track, we ran the car the following weekend and ran .200 faster with just doing the TB!
    I know of one person on thirdgen.org that dropped a tenth or two putting a 62mmTB on a iron head 3.1 but not sure what what else they have done to it!
    14.96@91.47 in the 1/4
    9.63@74.36 in the 1/8th
      • 13533
      Given the small area of the pushrod plenums, it makes sense that a larger TB will help out.
      • BMC
        • 146
        3.4L Throttle body
        Just make sure you port match the manifold. The casting is a bit off even for the stock TB on all L32 3.4L that i have had through the doors.
        -BMC.
        MG & MGB V6 + V8 Engine Conversion Shop
        1982 Chevrolet S10 long box with another L32 SFI!
        1980 MGB with Camaro L32 3.4L SFI V6
        2000 Venture 3400 (for her)
        Spitfire L32 3.4L
        "Experimentals"
        and more conversions all the time.
        • BillS
          • Oct 2005
          • 132
          Same thing on the Fieros, plus there is a restrictive area in the 'neck' that makes properly relieving it a problem.
          At least the Camaro 3.4 manifold is easy to relieve.
          • BMC
            • 146
            True.
            Probably just like the fiero, port matching is a good idea as well at the time between the upper and lower halves, but these are usually pretty clean, just a little deburring along the edges to clean it up.... But i figure with your project, you'll probably be porting heads and manifolds.
            -BMC.
            Spitfire L32 3.4L
            "Experimentals"
            • BillS
              • Oct 2005
              • 132
              Originally posted by BMC
              True.
              -BMC.
              You bet - nothing like free horsepower!
