3100 Graphite Headgaskets?
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    I found GM part number for a set for a 3400 but I'm wondering if there's a p/n for a set for a 3100 as well. The reason for wanting graphite is for moderate boost (~10psi) after a ported/polished top-end swap with a 3400. I was told to use the 3400 gaskets but that didn't seem right to me. Thanks in advance if you guys can point me in the right direction.
    1995 Grand Am SE
  • tejohnson
    • 359
    Re: 3100 Graphite Headgaskets?
    Are you using 3100 or 3400 heads?
    Regards,
    Todd E. Johnson
      • 13533
      RE: Re: 3100 Graphite Headgaskets?
      Is your motor a 3100 or 3400, that is the real question. Heads are the same for 00+ 3100 and 3400. How is graphite going to hold better than a felpro set?
      • tejohnson
        • 359
        Don't graphite gaskets hold up better to deterioration due to "hot spots"? Of course, this is just my limited knowledge via google, and noticing they are used with a lot of forced induction setups (other than copper).
        I had been using the older 3400 head gaskets from a rebuild ~3 years ago. They were holding up, however, they were starting to somewhat bubble up around the coolant passages on the block where there is no corresponding passage on the heads....
        Regards,
        Todd E. Johnson
        • Azrael
          • Apr 2005
          • 763
          Sorry. It's a 95 3100 block with 96+ 3400 heads.
          1995 Grand Am SE
          • tejohnson
            • 359
            Well, if no one else is going to answer... I don't understand why it would be a problem. But, I am always willing to learn someting new
            Regards,
            Todd E. Johnson
              • 13533
              I would be using 3100 gaskets on a 3100 engine. I don't have any idea what the purpose of 3400 gaskets on a 3100 would achieve.
              • ProjectMM
                • Mar 2004
                • 170
                what is the part # for the 3400 graphite head gaskets? while where on the subject
                2002 Pontiac GrandAm GT1
                3400 v6
                TOG headers
                RSM 62MM T-body
                FFP underdrive pulley
                GRANATELLI MAF
                Ported upper intake
                MSD DIS 4 ignition box
                MSD Wires and coils (pending)
                Venom high flow fuel pump (pending)
                • Azrael
                  • Apr 2005
                  • 763
                  GM 3400 Graphite Headgasket: part # 12577403
                  1995 Grand Am SE
                  • Mars
                    • Apr 2004
                    • 826
                    Hmm, wonder if I should use that part number for when I do my head gaskets in the springtime...
                    Are felpro gaskets just as good?
                    • tejohnson
                      • 359
                      Sorry to correct you, but that is the old part number (What I just pulled off my car). The Graphite gaskets are: 12589907
                      See:
                      Old: http://groomlakelabs.com/gallery/phase_three/IMG_2599
                      Old: http://groomlakelabs.com/gallery/phase_three/IMG_2600
                      New: http://groomlakelabs.com/gallery/phase_three/IMG_2604
                      Regards,
                      Todd E. Johnson
