Building an intake question
  • BigNorm
    • Mar 2005
    • 4
    I'm interested in building my own intake. I currently have a carb'd 2.8L in my Jeep Cherokee. I'd like to buy an entire 3.4L RWD shortblock with 2000+ heads. The problem being is that there is no manifold available to run a carb. Is there anywhere I could buy intake flanges for? Could I make a custom valley pan to keep the oil in? Any info on this would be greatly apreciated. I'm gathering info on this build as I go. Any information you could provide would be greatly appreciated.
    • 13533
    RE: Building an intake question
    I would imagine it would be easier to take the stock gen 3 lower intake and cut out the parts you don't need and then weld your own tubing to a carb plate. That would keep the flange and valley portion sealed and save you some expense at the same time. That is how I would go about it anyway.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Agreed. However getting equal fuel flow to each runner may be a task since they are all seperated far apart.
      If I had heads I could make a flange no sweat. I could also bend you a valley pan aswell. But I need a block with heads on it.
      Or if someone has a CAD drawing I can cut flanges in no time. But I doubt anyone has a drawing for it.
      • BigNorm
        • Mar 2005
        • 4
        How about multiple small carbs?
        • Guest
          you can always buy a 6 ITB intake from Ryan falconer for $1500 for the aluminum heads
            • 13533
            Wouldn't that involve converting to EFI though? Motorcycle carbs perhaps? Would probably give you more even fueling though isn't the stock carb setup a 390 CFM? Im pretty stupid when it comes to carbs:P
            • Guest
              Good luck with those flanges....
              They'll need to be CNCed, from a 1 or 1.25" (I don't remember what I came up with) thick piece of material, and machined out to provide clearance for the rockers and pushrods, and still provide a sealing surface for the valve covers. Definatly not like building a SBC intake starting with flat flanges.
              • sharkey
                • Jun 2004
                • 2061
                why not just convert to EFI??? it can be a bit of a task, but nothing near building an intake manifold. aside from the dificulty, there are the added benifits of an efi system.
                • Guest
                  QFT!
                  • geoffinbc
                    • 5831
                    Agreed. Every time my dune buggy chokes out off camber or under hard braking I want to get out and smash the god damn carb with a hammer...
                    As soon as I find an EFI donor it is in.
