LS6 valve springs
  • lakerbrad
    • 2
    LS6 valve springs
    I have a question about the LS6 valve springs. I am trying to figure out which ones to order i have got a jbodyperformance regrind cam for a 3100 and i am going to upgrade from the stock 3100 springs to the LS6 ones. i have found to compcams part numbers 26915 and 26918 the only difference i can see in the break down of the two is the inside diameter of the springs. Which ones do i need to get and is there anything else that i will need to purchase to do this swap. I did a search and got this much info but could not figure out which ones was needed. Thanks for the help.
    Brad
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    No the size is identical. The spring pressure is different. The 918's are stiffer.
    Get the 915's. The 918's are not needed unless you have a pretty radical regrind.
      • 13534
      You should ask jbodyperformance what valve spring specs are required for your regrind.
      • geoffinbc
        • 5831
        LOL gimme a break Ben. You think they will know?
        I would go find a cam with similar specs from Comp and Crane and go by their recommendations.
          • 13534
          No I dont think they will know which is partly why I said it. However, they SHOULD know or be able to get the information. I would expect that from a regrind as it is information you would recieve from crane or comp cams with a regrind (seen it). Its important to know.
          I would just use the stock LS6 springs unless the comp springs are cheaper.
          • tejohnson
            • 359
            When you can pick up the Stock LS6 Springs from Lingenfelter for only $65 for 16? Don't think the Comp springs are that cheap
            Regards,
            Todd E. Johnson
            • lakerbrad
              • 2
              They sell the entire set for $65
              • tejohnson
                • 359
                Also posted in the thread "Some parts to look at (Valvetrain)"...
                Regards,
                Todd E. Johnson
                • torq455
                  If I only had money!!!
                  • 1615
                  Wow! Awesome deal! I've seen those go for more than $100 on ebay.
                  Andy
                  fastest 1/8: 10.19@ 67.17
                  fastest 1/4: 16.16@ 82.70
