Lunati Valve Springs.
  • JMo60
    • Oct 2005
    • 300
    i can try to get a part number.. ill have to wait till the parts guy is back at the dealership
    94 Grand Prix
    • Fiero11
      • Apr 2005
      • 64
      It is hard to compare these various valve springs. Can someone put a table together so that we can compare apples to apples for LS1, LS2, LS4, LS6, LS? Here is an example:
      Crane 99838 Dual Springs
      Seat pressure at installed height: 110# @ 1.688
      Open pressure and height: 320# @ 1.208
      Coil bind: .950
      Average spring rate: 438#/in
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        LS 1 2 4 are the same
        LS6 is more
        LS7 even more with a different taller install height
          • 13531
          I thought the LS2 and 6 were the same spring. gmpd doesn't list the old LS6 part number any more (green springs). They sell the yellow one which I had tested.
          • El_Diablo
            STFUniversity
            • 917
            the green ones had less pressure IIRC
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              #21
              Which LS? springs can handle 6XXX RPM (Head PnP, Mild Cam)?
              What retainers would you get?
              This is for a Gen2 60\/6.
              • geoffinbc
                • 5831
                #22
                Thats info right from GM
                • geoffinbc
                  • 5831
                  #23
                  Check your cam card.
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    #24
                    I would, but I can't find it. Also, I plan to goto a different cam (more lope).
                    • geoffinbc
                      • 5831
                      #25
                      Then post you specs and we can help you out.
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        #26
                        Alrighty then, when I get the cam in the mail I'll try my best of getting it up on here.
