Stock Springs
  • bu01
    • Apr 2004
    • 91
    what springs would you guys recommend for .563 of lift
    • BlackJack
      Jack Wagon
      • Sep 2005
      • 84
      that depends: How high you going to rev?
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        Originally posted by Syn
        to save money you usually keep the v6 retainers and get ls1 shims,idk about on gen 2 heads tho just see how they seat with gen 2 shims.
        also if i were you and going with that much lift i'd just get the ls2
        So LS2 springs for the win?
        From my orignal idea;
        A}}} LS6 Springs, Gen 2 Retainers, & Gen 2 seats.
        Or should I go with:
        B}}} LS6 Springs, LS2 shims, Gen 2 Retainers, & Gen 2 seats.
        Where would I get the shims IF this is the right choise, GM stealer?
        I am looking for something in the 6200RPM range.
        Would LS2 get just as great?
        If so would I do this:
        C}}}} LS2 Springs, LS2 shims, Gen 2 Retainers, & Gen 2 seats.
        Where would I get the shims, GM?
        Thanks for the info.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          You cannot use Gen II retainers they do not fit the spring.
          If you buy the comp springs you should be able to get them cheeper.
          • Froggx
            • Jul 2004
            • 385
            I believe the later LS6's and the LS2 use the same spring.
            • bu01
              • Apr 2004
              • 91
              #21
              6300 -6800RPM
              • geoffinbc
                • 5831
                #22
                Nope I though so to but the LS 1 2 and 4 use the same, The LS6 is stiffer. The LS7 is stiffer still with a taller install height.
                • geoffinbc
                  • 5831
                  #23
                  Comp Cams 26918 good to .615 lift (at coil bind) with your 1.7" install height on stock gen III retainers. These are stiffer than LS6 Springs. But I looked up a COMP Roller cam with 270 duration and 510 lift and its recommended spring is slightly less than this one. So with your added lift I would recommend this spring to you. Also they should be cheeper than GM aswell. They are a beehive spring with ovate wire. I have already installed this spring on my bros 97 Vortec they are great.
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    #24
                    So then it's LS6 Springs, LS2 shims, LS6 Retainers, & Gen 2 seats.
                    How about if I used LS7 springs, then do I still need the shims and then just use the Gen 2 seats, LS7 Retainers?
                    • geoffinbc
                      • 5831
                      #25
                      No dont use an LS7 Spring. It is a different diameter. You do not need to buy LS retainers use Gen III retainers. Why do you need shims? Just put the spring on the stock seat.
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        #26
                        Someone said to use shims... ???
                        So it looks like I am going with this?
                        Gen III retainers, LS6 Springs, Gen 2 Seats?
                        Note* this is for a GEN 2 engine..
                        Thanks inadvance.
                        • geoffinbc
                          • 5831
                          #27
                          Yea that should work for you. You wont need to run a shim on the spring. Some people have mentioned locators. That will let you run any cam with up to 280 duration in the .5 lift range.
                          • BlackJack
                            Jack Wagon
                            • Sep 2005
                            • 84
                            #28
                            bu01: check with germ, I think he's got the perfect springs in mind for you that will handle your lift/rpm's without coil bind.
                            I had similar issues and he worked it out for me just fine.
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              #29
                              Yea, I think the cam I am looking at would be the 272 or within that area, then for boost around 10 PSI. I want to see atleast 6400RPMs without float.
                              So my final choice is:
                              Gen III retainers, LS6 Springs, Gen 2 Seats.
                              Why would I want locators? For less of a chance of it moving? I kind of think I might want them, but if they really are no big deal.... I don't feel like finding those. If you think I would want them, link me with a part number could ya? Thanks.
                              • bu01
                                • Apr 2004
                                • 91
                                #30
                                would you happen to know what spring he used
