Stock Springs
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    #46
    Well this is for a Gen 2 MPFI, so would all this apply to my setup?
    LS6 retainers, LS6 Springs, Gen 2 Seats, Gen 2 stem seals all in a Gen 2 MPFI.
    I am going to say "Yes!" . Just to make sure I don't buy anything I can't use.
    • AaronGTR
      boost lover
      • Jan 2004
      • 708
      #47
      As long as you have the same valve stem diameter than I'd say yes, it should all work.
      '97 Grand Prix GT 3800 (sold)
      Gotta love boost!
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        #48
        Stock replacement valves.
        • kprofthestrs
          • Feb 2006
          • 70
          #49
          i read throught this post. since the talk was a gen 2mpfi. i'm going to ask the ?. would this same set up work on a 01 3400.
          i read the final choices were ls6 springs w/ retainers, and gen 3 seats.
          just curios. was think of getting the crome moly rods that would do the same to reduce valve train float in the upper rpm's. if this set up would work it would be a tad easier to do than rods at this point.
          • Syn
            The Master Piece
            • Oct 2005
            • 599
            #50
            i did the ls6 spring swap on my '00 heads you use the ls1 shims,and depending on who you talk to 3.1 valve seals or chry 318
            • kprofthestrs
              • Feb 2006
              • 70
              #51
              ok what about the locks? stock? ls1/ls6?
              • Syn
                The Master Piece
                • Oct 2005
                • 599
                #52
                i used the stock ones, i guess if you wanna be super high performance you can get non stock ones
                • kprofthestrs
                  • Feb 2006
                  • 70
                  #53
                  ok since i am not planning on a cam change in the near future. would the
                  ls6 springs be too much for the stock cam? should i just use ls1 springs for now.
                  as i see it would be either ls1/6 springs
                  ls1/6 retainers
                  stock locks and seats
                  or am i confused?
                  • Syn
                    The Master Piece
                    • Oct 2005
                    • 599
                    #54
                    ls1/6 retainers
                    or am i confused?
                    you use the ls1 shims,idk about lsx springs on a stock cam but i am sure you can. someone will chime in just to make sure
                    • AaronGTR
                      boost lover
                      • Jan 2004
                      • 708
                      #55
                      Locks and retainers are the same. They both use 8mm diameter valve stems.
                      You could use LS6 springs on a stock cam, but they are probably overkill unless you plan on using a lot higher rev limit than stock.
                      Before I switched cams I used LS1 springs on my 3400 w/stock cam for a while and they worked just fine. Open pressure is almost the same as the stock springs, but seat pressure with the valve closed is a little higher. Overall they are just a tad stiffer than stock which should prevent any float at close to 6000rpm.
                      Gotta love boost!
                      • Rhedalert
                        Dr. Feelgood
                        • 1574
                        #56
                        I had LS6 springs in my old engine with stock-everything else (used my old heads during a changeover to roller rocker arms and I had them assembled with those springs). I want to say it was better at 5500rpm+ but also the engine had 120k so the stock springs were probably even weaker.
                        Brian
                        3400 SFI V6, 4T60e
                        • kprofthestrs
                          • Feb 2006
                          • 70
                          #57
                          so the basic's would be ls1 springs and reuse all the old retainers and locks until i do a cam change over.
                          if i did use ls6 springs would it cause to much stiffness in the valve train?
                          just want to know in cause the ls1 are hard to come by.
                          • AaronGTR
                            boost lover
                            • Jan 2004
                            • 708
                            #58
                            The LS6 spring shouldn't be too stiff for the stock parts, so if you plan on adding a cam later, might as well put them in now. Either spring should be readily available and cheap.
                            Gotta love boost!
                            • CustomJBody
                              • Mar 2006
                              • 1
                              #59
                              ok now can i get these ls2 or ls1 springs at advance auto parts?
                              • AaronGTR
                                boost lover
                                • Jan 2004
                                • 708
                                #60
                                Um... call them and find out? I have no clue. My dad worked at a GM dealership so I just ordered everything thru him and got them for wholesale. I'm pretty sure you can get them on gmpartsdirect.com too though.
                                Gotta love boost!
