I may have found 1.7 Rockers
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Go to page 85 and check out P/N E928062
    They use a 3/8-24 stud and are listed for the 4.3L. All 4.3L's since the later 80's used centerbolt covers. So they should be narrow body
  • tejohnson
    • 359
    So buy 'em, install 'em, and let us know how they work out
    Regards,
    Todd E. Johnson
    • geoffinbc
      • 5831
      Fine give me the funds...
      I checked Summitracing but they have zero specs
      • tejohnson
        • 359
        That's not how it works... lol You brought the solution to the table, you get to fund the project
        I am assuming you could stick to the same pushrod lengths, but the back of the rocker looks quite thick. I have been sitting on the fence wrt buying some full roller rockers or not. They are a bit cheaper than the crane gold...
        Regards,
        Todd E. Johnson
        • geoffinbc
          • 5831
          Yea they are cheeper. I e-mailed them to ask wether or not they are narrow body. If they are this is the ticket for 1.7 rockers.
          The next best thing is Harland Sharp 1.65 ratio rockers which I know are narrow body.
            • 9190
            http://60degreev6.com/discussion/dlo...ile&file_id=92
            For some odd reason the DWF doesn't open up automatically when you just DL it regularly, so try to save it somewhere then view it with a DWF viewer. Anyway, there is a scan of a stock 3x00 roller rocker (1.6) and a stock 4.3L stamped rocker (I'm assuming 1.6), imported into CAD and dimensioned.
            You can all decide from there....
            • tejohnson
              • 359
              Originally posted by bszopi
              http://60degreev6.com/discussion/dload.php?action=file&file_id=92
              You always have to be the party pooper Well, I bought that double roller cloyes damn it
              Regards,
              Todd E. Johnson
              • onefastV6
                • Sep 2005
                • 880
                Judging from the pics and dimentions, they are only 0.0453" off. However if you take into account that factory GM rockers are not known for their preciseness the gap might open or close a little. These do look as if they might work, however being non self alinging the gen 3 guys would need to use guide plates and heat treated pushrods.
                2000 Grand Am GT
                2011 Chevy Impala
                • geoffinbc
                  • 5831
                  Sorry Brad the 4.3L is 1.5 ratio.
                  • Syn
                    The Master Piece
                    • Oct 2005
                    • 599
                    i somewhat posted some info on this last year and poeple asked whats the point? its over kill pretty much
                    • El_Diablo
                      STFUniversity
                      • 917
                      the ratio is different....... hows that overkill?
                      • Doubt_Incarnate
                        I still watch ROBOTECH!
                        • Jan 2005
                        • 1130
                        i think for the dollar id just get a cam, instead of 5hp i'd get a lot more from a cam for a hundred less. but then i bought the crane rockers and a cam so i guess i'm all about over kill.
                          • 13525
                          Not everyone is going to want to pull their intake manifolds and cam to install a new one. Higher ratio will possibly be more than 5 hp too, hard to say right now. Im still waiting to hear back from thunder racing on the stock cam specs.
                          • Syn
                            The Master Piece
                            • Oct 2005
                            • 599
                            mybad i was saying is they told me whats the point, its over kill
                            but i agree with you
                            • geoffinbc
                              • 5831
                              Well herd back from Mr.Gasket. They are not narrow body rockers
                              Its dumb that they list them for an engine that uses centerbolt covers in stock form.
                              So far the best bet is still Harland Sharps 1.65 ratio. Thats as high as we're gonna get without going custom.
