will 2000 3100 heads fit my 96 3100?
  • no_doz
    • Sep 2005
    • 912
    topic?
  • torq455
    If I only had money!!!
    • 1615
    yes!
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    • no_doz
      • Sep 2005
      • 912
      will i -have- to tune it for them, or do anything other than swap em?
        • 13525
        I doubt you would need to tune for a 1mm larger intake valve. Its not going to be perfect, but then again, stock wasn't perfect either for tuning. Don't worry about it if you can't tune it unless you do a lot of mods.
        • torq455
          • 1615
          thought the 96 v6's have a MAF. the ECM will know it's getting more air and adjust for it. thus, tuned!
          Andy
          • Syn
            The Master Piece
            • Oct 2005
            • 599
            agreed!
            • sprucegagt
              Old School KI
              • May 2005
              • 703
              Uumm, NO. If that was the case there would be no need for tuning software.
              Your local OBDII moderator
              2000 Grand Am GT w/ WOT parts
              • Syn
                The Master Piece
                • Oct 2005
                • 599
                i don't think he ment the increased air from say forced induction, just basic bolt ons and ect, cause a computer can comensate a lil bit
                • torq455
                  • 1615
                  the need for tuning software is required for fine tuning for more HP. i know someone who had an 87 Camaro IROC-Z and using the stock chip added a paxton S/C on it with 6 psi, stock engine. yes, that had a MAF. It did just fine. However, the S/C kit did include water injection. without that, it'd detonate like hell.
                  Andy
                  • sprucegagt
                    Old School KI
                    • May 2005
                    • 703
                    Tuning software has many more uses than just fine tuning for HP. Switching from N/A to boosted applications require substantial tuning changes to the PCM. The water injection was only a stop gap measure and should NEVER been needed for just 6 PSI. Trying to use N/A timing for a boosted application is stupid. The timing tables for both applications are completely different.
                    I'm sure that engine ran just fine for regular driving. During regular cruise conditions the engine is still operating under N/A conditions until boost kicks in. Yet, I'm sure it was lean when wide open. Know how many miles have been put on the car since the S/C install?
                    • Syn
                      The Master Piece
                      • Oct 2005
                      • 599
                      i'd have to argue with that, my saturn ran perfect with stock pcm and just larger injectors i ran 10psi on it no problem intercooled and broke mid 14's in the 1/4
                      if tuned yes and traction it could have done a hell of alot better but its possible to run stock pcm's with boost
                        • 13525
                        Stock computers don't tune themselves. They adjust...but thats far from tuned. After messing with phil's grand am in stock condition, i can tell you the stock tune isn't tuned too well. Fueling was off, and quite a bit of KR. Throw a ported 3500 plenum and 65mm TB....more KR, more fueling issues. This is MAF...supposedly able to compensate better than MAP. What a joke. I should add this shit to the myth page cause its so wrong its not even funny.
                        End of post...im writing an article.
                        • sprucegagt
                          Old School KI
                          • May 2005
                          • 703
                          1. You didn't completely read my post.
                          2. At 10 PSI, it had KR out the ass unless the larger injectors were so big it drowned the KR. Once again this is a stop gap measure. Stock timing should of been reduced.
                          3. Ben said everything best on this!
                            • 13525
                            http://60degreev6.com/discussion/kb....=article&k=114
                            Feel free to help me make it more clear cause im kinda tired and I gotta go flowbench a set of heads. I know what im thinking but I don't think I wrote it too clearly:P I didnt even touch base on the MAP setup (wrote stuff on it, then realized I was jumping around way too much).
