best single performance mod for under $200?
  • fieroman87
    • Mar 2006
    • 8
    have a friend that just purchaced a 3400 Impalla '03? wants some more "pep" without breaking the bank. havn't found an intake for this application yet, and S&S headers are $560 so those are out of the question. what's a remaping of the PCM run? and what are the gains?
    thanks,
    Arty
  • onefastV6
    • Sep 2005
    • 880
    I would go with a DHP 1.0 PCM. They have lowered the pricing to $100 now, and it has been a proven mod for alot of people. Not only will the shift points be raise and the shift be a little firmer, the timing will be slightly increased and the fans will stay on after he shuts the car off for exta cooling.
    With the other $100 I would save for something bigger in the future.
    2000 Grand Am GT
    2011 Chevy Impala
    • vsop4me3.1
      • 482
      with that other hundred bucks he can make a homemade intake
      I wish 10% of the people on the road knew how to drive
      • El_Diablo
        STFUniversity
        • 917
        or get a new (less restrictive) muffler and have it installed and still have a lil left over
          • 13533
          Id save for the programmable DHP setup so that any future mods can be accounted for in the computer.
          • kflo 93 gt
            Bangin' Gears
            • Nov 2003
            • 238
            For this guys wants, I think the DHP 1.0 and a homeade intake would be a nice addition. It'd be a bit throatier, but still quiet, and it'd probably have atleast 10hp over stock. That seems like a nice way to spend $200 to me.
            14.60 @ 96.33 for now...
            • El_Diablo
              STFUniversity
              • 917
              idk, he could drop more weight and pick up a lil more power from the exhaust....i would prolly add 50 to the budget and do the intake too though
              • Syn
                The Master Piece
                • Oct 2005
                • 599
                buy a cone air filter, what 30 bucks, 15-20 on ebay
                diff muffler theres some cheap ones for under 50.
                maybe some larger pipe from the cat to the muffler as well
                should be around 200
                • fieroman87
                  • Mar 2006
                  • 8
                  well the intake (home made) is a given, knowing how restrictive the factory stuff is. i was thinking a muffler as well but volume becomes an issue, and i can't think of any QUIET performance mufflers.
                  where do i get the PCM programer and for how much? what gains are seen (objectively)?
                  i was also thinking of fabricating an undertray for better air flow (help with efficiancy).
                  the plugs are comming out in favor of standard resistor type... i found that these blocks like them better than the platinum counter part.
                  so the pricelist comes out like this:
                  plugs- 1.89 ea. (12.02 w/ tax)
                  home made intake- $25 for filter, $15-30 for the tubes and connectors
                  DHP 1.0- $???
                  muffler- about $80 (flowmaster 60 series)
                  can anyone fill in the blanks/add to the list?
                  thanks,
                  Arty
                  • Syn
                    The Master Piece
                    • Oct 2005
                    • 599
                    haha you want a quiet muffler and buying a flowmaster
                    60's should be fine tho depends on what u call quiet. just geta 40
                    increase the pipe size fromt the cat back
                    • 88GTRacer
                      • Sep 2005
                      • 41
                      He can get an FFP underdrive pulley for the 5-10 hp increase. It's $110 shipped. Then you still have enough for a K&N drop-in filter ($35.69 plus S&H) and have enough green backs for an oil filter change too!
                      Later,
                      88GTRacer
                      • El_Diablo
                        STFUniversity
                        • 917
                        the dhp reprogramed PCM would be better because it will decrease shift time and effectively remove the speed limiter and give you a better tune
                        it was said somewhere earlier in this thread that its around $100 now
                        that along with the homemade intake and free flowing muffler should give you a noticeable increase in performance
                        • JMo60
                          • Oct 2005
                          • 300
                          get a used nitrous system, thats the best way to spend your money
                          94 Grand Prix
                          • El_Diablo
                            STFUniversity
                            • 917
                            uhhh... no
                            your money will be gone after buying the basic stuff (bottle and selonoids) and not to mention you would still have to fill it.... and then keep refilling it
                            • gboogie99
                              they still can't catch me
                              • Nov 2005
                              • 348
                              best mod you could do is a 60degreev6.com sticker...that should get you an extra 50 whp with no tuning
