60degree V6 store Valve Spring Question
  • john_V63400
    Banned
    • Feb 2006
    • 409
    Are the comp cam 26986 valve springs a direct replacement to your stock springs. These are the springs sold at 60 degree store.
    I know the LS6 and LS1 springs arent.
    I really dont want to do any modifications to make new springss fit. Thats why Im asking.
    • 13530
    They drop right in with no modifications. I would use the comp retainers and keepers as well for the best possible fit but stock retainers and keepers will work as well.
      • 13530
      Stock on the left, comp 26986 on the right.
      • john_V63400
        Banned
        • Feb 2006
        • 409
        And also are these valve springs stronger than the stock ones
        Will they reduced valve float?
        How do they compare to the LS1 & LS6 springs.
          • 13530
          I had them tested at 115# @ 1.7 and 186# @1.3. That puts them between the LS1 and LS6 spring that were tested. They are a better design than stock as well, although still beehive shape, the oval wire helps even more with harmonics.
          • torq455
            If I only had money!!!
            • 1615
            did comp make different springs? i have one (no part #) 1.7 is 122 and 1.3 is 280.
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
