Forged Pistons
  • Darin
    • May 2006
    • 259
    Forged Pistons
    I am looking for a place that sells a good/resonable forged piston for the 3.1. any suggestions? I will be using nitrous on the car.
    What brand of pistons have you guys used? any horror storys?
    1999 Grand Prix SE 3100
    1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
    1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
  • jp_grasshopper_007
    Power Level:1,000,000
    • Mar 2006
    • 120
    haven't found any yet but still looking for Ben, short of having them custom made. how much juice r you trying to squeeze? if you're going 150 or less H's would be fine, IF you KNOW you can tune it.
    because I\'m not Canadian
    • Darin
      • May 2006
      • 259
      Looking to spray somewhere in the range of 125-150.
        • Mar 2006
        • 120
        speed-pro makes a H piston with a coated skirt. that should be good enough as long as your tune is @ perfect. I think Ben can get these for you.
        • 614streets
          • 344
          Just call arias or ross , dont run nitrous on hyperutectics.
          1992 Chevrolet S10
          2.8 v6 tbi 5 speed
            • 13533
            Why not? SO long as its tuned properly there is no reason to use forged. Stock pistons took a 200 shot more than once so 125-150 with a good tune would be fine. Why? Because forged pistons are better for when you have detonation, but hyper pistons are better when you have no detonation, especially on a street driven car. Forged pistons require more clearance with the cylinder wall due to thermal expansion.
            If you aren't sure you your tuning ability/getting it setup properly, then you better get the strongest parts you can, which would be forged pistons. However, for 900 bucks vs 200ish...yeah, id rather tune it.
            • Darin
              • May 2006
              • 259
              Ben, see what kind of price you can get me on the hypers.
                • 13533
                Are you sure? I ask because the tune is vital. How often are you going to be running the nawz? Have you used it before and set it up or are you having it installed and the computer tuned for it? Wet/Dry shot?
                Im still confident in the hypers ability but I want to make sure you are going to be setup for it. Ill get a price tomorrow. What size (stock, overbore?).
                • Darin
                  • May 2006
                  • 259
                  I have had several cars with nitrous.
                  In fact one was a stock internal, stock heads, and cam. 95 LT1 Camaro. that went a best of 10.98 @ 123 mph, 1.47 60 foot. So yes I feel confident with running nitrous.
                  As far tuning goes I will probably go with a FAST engine management system. (If its compatable. I still have to contact them.
                  I just want a price quote for now, STD bore. I am considering building a pretty modded 3.1 Grand Prix. One I hope will compete with some of the Fastest 3.8 GTP times.
                  Here is a photo of the Z28
                    • Mar 2006
                    • 120
                    you can safely run a 75-100 shot w/stock cast pistons with a good tune, or just alittle more gas than you need w/a little extra retard
                    • z284pwr
                      • 88
                      http://cgi.ebay.com/ebaymotors/TRW-2...QQcmdZViewItem
                      There is an auction for Aluminum "PowerForged" pistons...
                      Oh and you are nuts running a 10.98 with *what I could see from the picture, no roll cage or roll bar in a convertible Camaro.*
                      Brian Edwards
                      '73 Trans-Am
                      '79 Suburban
                      '90 Beretta INDY
                      '90 Turbo Grand Prix
                      '04 TSX
                      '04 TL
                      • Darin
                        • May 2006
                        • 259
                        I refuse to put a roll bar in a convertible. Looks gay! I had been kicked out of many tracks due to running to fast. NHRA rules require convertibles running faster than 13.99 have a bar. a stock Z28 runs that from the factory. Most of th 1/8th mile tracks I run at dont care how fast it is.
                        Thanks for the link, I will check it out.
                          • 13533
                          You can't use the 2.8 pistons:P NIce find though.
                          Priced the hyper pistons with the coated skirts at 200 even.
                          • Darin
                            • May 2006
                            • 259
                            Yeah, I noticed they were 2.8 pistons.
                            I'll let you what I decide on the pistons Ben.
