3400 top end swap
  • MasterJacko96
    • Jan 2004
    • 61
    3400 top end swap
    i plan on getting P&P 3400 intake manifolds and a 62mm tb and swapping them on my 96 monte carlo with the 3100. Would i see any more gain if i swapped the 3400 heads as well porting them to match the 3400 intakes and porting the heads. I dont want to use new valves, or pistons just yet but could i still get them ported to increase flow? also would i beable to use my 3100 rockers and pushrods if If i used the 3400 heads? What all should I do?
    1996 Monte Carlo LS 3100 engine, 1/4 16.131 *RIP
    88 cuttlass supreme 2.8L coupe
    90 dodge daytona 3.0 v6
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Everything 3100 will work on a 3400. But 3100 heads had smaller intake valves prior to 2000. So get 3400 heads cuz they have larger valves or 3100 heads made after 2000.
    • Canada
      • 84
      1994-1999 3100s have an intake valve of 1.72".
      2000+ 3100s have an intake valve of 1.74".
      1996+ 3400s have an intake valve of 1.74".
      The exhaust valve is the same for all motors.
      Swapping heads isn't going to gain much at all.....maybe 2-3 hp.
      Swapping intake manifolds gains around 6-8 horse at best.
      So either go get the ENTIRE 3400, +20 hp, (I swapped one in for $550...that was EVERYTHING.) or headers, +18 hp,which should cost $500-$750.
      Aside from bolt-ons like intake, exhaust, or an UDP.....those are the two best choices.
      -1996 Beretta
      3400 SFI / 4T60-E
      -1991 Grand Prix SE
      3.4L DOHC / HM-284
        • 9191
        Intake valves on the newer heads is actually 1.76", not 1.74".
        • Canada
          • 84
          Really? Hmm.....I'm just reposting what the main page says....
          -1996 Beretta
          3400 SFI / 4T60-E
          -1991 Grand Prix SE
          3.4L DOHC / HM-284
            • 9191
            Where on the main page? Cause here is a section from the main page...
            http://www.60degreev6.com/index.php?p=pages&pid=69
            • Canada
              • 84
              Maybe I should try reading for once......because that was the page I was looking at.
              -1996 Beretta
              3400 SFI / 4T60-E
              -1991 Grand Prix SE
              3.4L DOHC / HM-284
              • MasterJacko96
                • Jan 2004
                • 61
                im not just swapping them im getting them Ported a lor the MAXIMUM AMOUNT i measured the opening on tthe 3400 intake manifold and it is 59mm not 58 and there is definatly enough material to matcch the opening of a 62 mm tb and the neck. the intakes are about twices as big on the runners as the old 3100 ones i put them side by side and looked im not gonna do the heads yet but im doing P&P 3400 intake manifolds, HEADERS, Exhaust, 62 mm tb, a fenderwall cai. doing all those mods should provide a hug gai nbut we'll see i'll get to a dyno and a track dont worry. any perdictions on how much i'll gain at the crank adn at the wheels?
                • Canada
                  • 84
                  Okay, so I didn't remember the exact opening of the neck....59 mm.
                  Trust me on this one, porting alone will get you know where. I can show you a dyno chart of a Beretta Z26 with Street Arsenal Stage 2 heads and ported upper and lower intake manifolds.....those mods made an additional 8 hp. We have a pretty good idea of how the other mods performed. This was with the stock exhaust manifolds....the shitty 3100 in fact. Get headers first.....they make 18 whp....then porting.
                  -1996 Beretta
                  3400 SFI / 4T60-E
                  -1991 Grand Prix SE
                  3.4L DOHC / HM-284
                  • MasterJacko96
                    • Jan 2004
                    • 61
                    the only reasone the beretta didnt make any Hp off those is because it has no headers. swapping 3400 P&P intake manifolds will increase the amount of flow no doubt but once it hits a restictive stock exhaust manifold it has no where to go. Thats why your no seeing any results with top end swap. I wouldnt do just P&P 3400 intakes without headers because theres no point because the exhausyt manifold will just slow the flow back down. However if you increase the size of the intake manifolds and then get Headers you will see even more of a gain. without headers P&P 3400 intakes on a 3100 will probably only give you a gain of 5 HP tops, but with headers and the intakes i bet the gain would be at least 30 hp combined. I know you guys are still gonna argue but i know theres some people that will agree with me and i will make sure to go to a dyno after all this stuff is installed. So does anyone want to take bets on how much Hp at the crank and at the wheels i will get?
                    • MasterJacko96
                      • Jan 2004
                      • 61
                      i perdict 168 Hp at the wheels or under 16 seconds for the 1/4 mile remember im doing headers, P&P 3400 intake manifolds also bored to 62 mm at the opening to match the tb, fenderwall cai, ffp ud pulley, dual/y piped exhaust.
                      anybody wanna perdict any thing different>? i want numbers not post whore answers like i dont think u will get that much hp which i might not
                      • Canada
                        • 84
                        Well, to be honest, no one knows what headers and 3400 intake manifolds will do.....no one has done it. So my prediction would be completely worthless as it wouldn't be based on fact...only what I think.
                        Saying that.....stock 3100s seem to make 122 whp. Headers are worth 18...140 whp....my dyno chart says an intake is worth 5 whp....145....FFP says there UDP makes 5 whp......150 whp.....exhaust seems to make 7 whp....157. Now, the manifolds....I honestly don't even no where to begin to guess these on a motor that has everything else correctly done. Think you can make 11 whp of these? I don't know.
                        Just as long as you are getting headers...good....great. Very good and very great in fact.
                        Now, how much is the 3400 upper intake manifold swap going to cost you? Keep this in mind.....I did my 3400 swap for $550....that includes everything...motor, fluids, seals, gaskets, and any new sensors or parts needed.
                        -1996 Beretta
                        3400 SFI / 4T60-E
                        -1991 Grand Prix SE
                        3.4L DOHC / HM-284
                          • 13534
                          SA porting blows, so while their products may only give 8 hp, I am sure a properly ported head/intake set can do a lot more. With headers, everything would be so much better.
                          • Canada
                            • 84
                            At least we agree on one thing.....we need headers.
                            Is Street Assenal still open? Their website done gone lost itself.
                            -1996 Beretta
                            3400 SFI / 4T60-E
                            -1991 Grand Prix SE
                            3.4L DOHC / HM-284
                              • 13534
                              Their site has been gone and back and gone and back...maybe its gone, I dont look for that shitty company. RSM should have had their fate but whatever. SA was proven to be junk and overpriced.
