Camaro 3.4V6 roller tip rockers, anyone?
  • z28quetzal
    • Dec 2004
    • 10
    I have a 3.4 V6 from a 95 Camaro in my TR6. I would like to add some Comp roller tipped rockers. I called Comp today three times, and three times I got different answers.
    Please, has anyone here used roller tipped rockers? I would like to go with the 1.6 ratio. Can somebody please provide me with the correct part number? Also, do I need to use guide plates with these rockers?
    Please, guys, this can't be rocket science! I would be very grateful for any help on this...
    Thanks,
    joe
  • sharkey
    • Jun 2004
    • 2061
    or with pushrods
    i run those in my motor, they bolt right on. you do still need the guide plates.
    • z28quetzal
      • Dec 2004
      • 10
      Thanks for the info. Cool!
      One question: what is the advantage of running the pushrod kit? Are the stock pushrods not good with the rockers?
      thanks,
      joe
        • 13520
        I sell these rockers on the store. I have used them on my old 3.1 aluminum head with the pushod guides.
        • Fedaykin
          • Aug 2005
          • 95
          Installed!
          comp cams magnum roller rockers 1.6
          high energy pushrods
          260 duration cam
          SI portflow valves
          lunati valve springs seated to 120lbs closed pressure
          • z28quetzal
            • Dec 2004
            • 10
            GREAT!!! That looks awesome....
            I see the guidesplates in the picture. Are they the 'stock' guideplates or did you buy them separate?
            Please, if you have the Comp part numbers I would REALLY appreciate it. Did you use the 1414-12 1.6 ratio roller tipped rockers?
            joe
            • Fedaykin
              • Aug 2005
              • 95
              yeah...
              rockers: COMP-1414.12
              cam: COMP-16.233.4
              springs: LUNATI-73943-12
              head studs: ARP-2334003
              valves: exh SEV-3188, Int SEV-3253
              the cam is really a mild cam by performance standards, crane makes some much better cams, i'd get one if I could go back... but I also don't mind not revving that high for now. I got the lunati springs before I did much research either, and they were just a budget solution. they needed a much higher install height and i got a machine shop to machine the seating surfaces down to accomplish this. I went a bit under the rec. install height though to get a little higher seat pressure... crossing my fingers I wont get bind. Also they lunati springs were not that evenly matched....
              I also have an underdrive pulley, 180* thermostat, NGK iridium plugs, high flow oil pump.
              you emailed me reguarding lack of aftermarket... here are a few websites to get you started.
              http://www.ftpp.net/V6Main.htm <--- most the usual stuff can be had here
              • torq455
                If I only had money!!!
                • 1615
                I got the 1.6's too. I've put about 25K on them and they are great!
                Andy
                fastest 1/8: 10.19@ 67.17
                fastest 1/4: 16.16@ 82.70
                • z28quetzal
                  • Dec 2004
                  • 10
                  WoooHooo!!
                  Thank you all for the info. I called ftpp.net today and the 1414-12's are on the way. I went ahead and go the pushrods too. Looks like I will be buying me a new cam soon! The info you guys have shared with me is great.
                  Thank you all much. Josh at ftpp told me today there are many mods to be made to the 3.4.
                  • Ortie666
                    • Jul 2005
                    • 340
                    Umm, can i see a picture of the car too? motor in it.. or it doing like 160 down a city street..
                    Six-t-Six Motorsports
                    2.8L Chevette Roadcar
                    3.2L Acadian Racecar
                    • BMC
                      • 146
                      Pretty neat! We have one-or-two of these motors in MGBs. Nice to hear about the TR6. Can you post pictures?
                      -BMC.
                      MG & MGB V6 + V8 Engine Conversion Shop
                      1982 Chevrolet S10 long box with another L32 SFI!
                      1980 MGB with Camaro L32 3.4L SFI V6
                      2000 Venture 3400 (for her)
                      Spitfire L32 3.4L
                      "Experimentals"
                      and more conversions all the time.
                      • Fedaykin
                        • Aug 2005
                        • 95
                        More togetherness... soon u can see it wedged in a miata.
                        • Green1995Camarov6
                          • Jul 2006
                          • 17
                          1.6 Rockers come standard on the 3.4l in the camaros. im not trying to sound rude, but the only performance gain is the roller tip. Also, less valve train wear
                          • Fedaykin
                            • Aug 2005
                            • 95
                            umm, the rockers on my camaro engine were roller when i yanked them...
                            • StudlyCamaro
                              • Nov 2003
                              • 692
                              where are you getting your info?
                              then you didnt have a stock motor, the stockers are stamped steel
                              3.4L camaro some goodies
