Cammotion
  • 95SleeperAcheiva
    ArtofOlivia"PocketRocket"
    • Jun 2006
    • 694
    Cammotion
    I went to cammotion's site and sent them 2, emails from their site.
    All I asked was "can you make me a cam for a 2004 3.4 GM Pushrod motor?" They have yet to respond.
    anyone else I can go to?
    • 9191
    How much are you willing to spend and how long do you want to wait?
    Crower will do one for ~$800 (half up front before they do anything) and it'll take them ~5-6 months to do it.
    At least, that's the cost and timeframe from spring 2002 when I was talking to them about getting one made.
      call Crane (iirc), they used to have blanks for roller cams (just a few months ago). Custom grind would be a little over $400.
      Cheaper than Cammotion
      *edit, i found the thread...
      http://60degreev6.com/showthread.php...ighlight=crane
      • 95SleeperAcheiva
        • Jun 2006
        • 694
        I don't mind the price, I'm just concerned with getting one, in the next few weeks, not months.
        • torq455
          If I only had money!!!
          • 1615
          what about Schneidercams.com ? they make a roller for the 3.1 block. i thought you could interchange cams between 2.8,3.1, and 3x00's. i am just talking about the journal sizes here.
          Andy
          fastest 1/8: 10.19@ 67.17
          fastest 1/4: 16.16@ 82.70
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            They only sell solid roller lifter cams. I doubt that is what he is looking for. Also on their component sheet it says "Call" for part numbers and pricing. Sounds like they make them and price them as needed. Sounds expensive.
            • Guest
              noone thought of milzy? if you are on a time frame, he can prob do it.
                • 9191
                Milzy goes through Cammotion... Might be one reason they aren't responding to you though.
                  Last price quote i got from Milzy on a custom grind was like $480
                  betterthanyou, if they have the cores for those they can grind them as a hyd roller.. the Crane tech told me they use the same cores... it's just the profiles that are different between the mechanical and hydraulic.
                  • TurboZ24
                    • 299
                    Crower sometimes is unwilling to do it for certain people for some reason. When I called them back, they said 500.00 and a month to make the cam. Now, I have bought one from them before, so.
                    Curtis
                    91\' Turbo Z24
                    http://www.turboz24.com
                    • Ortie666
                      • Jul 2005
                      • 340
                      Wholy its like 400-500 for a 3x00 cam? its kinna hard to beleive no company has started to make cams for these engines
                      Six-t-Six Motorsports
                      2.8L Chevette Roadcar
                      3.2L Acadian Racecar
                      • billy wood
                        • 10
                        Delta Cam??
                        • geoffinbc
                          • 5831
                          Yea Delta Cams is good. Just regrind the stock one and quit messing around finding some niche supplier. A regrind is just as good will most likely get you the specs you want and be a HELL of alot less.
                            • 13533
                            I want to try something with an overlap a regrind can't do. Id like to know what kind of price/time frame I can get for 5 custom cams.
                            • zofo61
                              Banned
                              • Oct 2005
                              • 436
                              With the 3500 topend on my 3400, I REALLY want a cam that is HP but streetable, . Ben knows my goals and maybe a group of 3400's can get together and make it less costly.? Keep the thread alive....too many people want one to let it die.
                              I called Cammotion BEFORE Milzy bought all the 3400 blanks and the #s they gave me "Supercharged" were:
                              IN: .209
                              Ex: .218
                              IN LIFT : .489
                              EX LIFT: .542
                              Lobe Sep: 109
                              but there is one more spec I cant find and that is the CenterLine Spec:
                              Ben has these numbers from a thread I got into trouble over a long time ago but I think these are the specs milzy is using for his Stage 2..........?
