questions,problems,eveything is never ending
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    is this how your connecting the red and black cables to you aldl port?
    what all cables are you using?
    • Syn
      The Master Piece
      • Oct 2005
      • 599
      i use the black and red wires only
      of course my connector is turned counter clockwise so the a would be on the left and red goes on the right.
      this is what i was told to do from the mastach website
      • sil
        4T60-E killa
        • Nov 2004
        • 723
        oh, so its like this
        and you use TOP, black left, red right ????????
        seems like its connected properly
        so if someone else was able to get logs from your car...
        what program was he using?
        • Syn
          The Master Piece
          • Oct 2005
          • 599
          yep exactly like that
          he was useing freescan as well, except i had a older version, so i went and downloaded a newer version and the same prob
          i've tried datalogging on 3 diff laptop's
            • 9191
            Just for shits and grins... have you tried swapping the black and red wires?
            I haven't messed with datalogging in forever, but I know Freescan can be touchy sometimes. I know Ben mentioned it somewhere, but the scan/capture rate needs to be at a certain value, and you have to "kick-start" the program to get it to start datalogging.
            • Syn
              The Master Piece
              • Oct 2005
              • 599
              #21
              yeah i tried swapping them, i dind't know there was a certain value needed maybe thats it?
              • sil
                4T60-E killa
                • Nov 2004
                • 723
                #22
                ya you have to "Force Data" lots i have to do it up to 10 times
                youll notice that its working properly when you see
                Bytes Sent and Bytes Recieved both moving
                the P4 ecms require you(logging software) to "Ask" for data before the ecm sends it
                so if you dont see the "Bytes Sent" moving, then your not getting and data
                you can fiddle around Milisecond Delay maybe make the number higher by 50 ms ata time
                im sure the lower you go the more prone its going to be to errors as there will be less time for the software and ecm to communicate
                im guessing your running the 7730 ecm
                can you do us a favour and look at the sticker on your ecm case and tell us what the numbers are
                same with the eprom inside, there is a sticker ontop the blue rectangle thing, thats your eprom
                im not sure what a 93 cav uses, but it will help us to know forsure what your running
                im currently trying to find other software that you can try to use
                • Syn
                  The Master Piece
                  • Oct 2005
                  • 599
                  #23
                  ecm case says bfuz not sure if you want the numbers but i am sure thats all you'll need
                  eprom says the same thing
                  but 3200 under the bfuz
                  most of the time i'd hit force data and it woudl read only temp and it would say 32 degrees and everytime i hit force data it would go up 32 degrees so at one point my temp was 1000+ lol right
                  • sil
                    4T60-E killa
                    • Nov 2004
                    • 723
                    #24
                    might be a bit old, but its sapposed to work with 730 and 727 ecus
                    worth a shot
                    dos program
                    ecu file
                    the readme (read it)
                    main directory of files
                    Main page
                    if you cant get this program to run in xp then youll need an xp boot disk to run it in dos mode
                    check out bootdisk.com, get the xp boot disk for dos
                    Bootdisk, Boot Disk, Windows Boot disk, XP Bootdisk, 98 Boot Disk, Setup Disk, Startup Disk, NTFS Bootdisk
                    • Syn
                      The Master Piece
                      • Oct 2005
                      • 599
                      #25
                      its confusing since i haven't messed with a dos program in maybe a few years when i did c++ in h/s.
                      now do i have to load the ecu file cause idk how to and the readme isn't helping much
                      aslo it says it only runs off com1 or com2 ports my usb are only com 5 and 6 so the program is saying the cable cant be found
                      • sil
                        4T60-E killa
                        • Nov 2004
                        • 723
                        #26
                        rough lol
                        can you manipulate whatever is using com5 or 6 make it use like com 7 and then have whatever is using com 1, make that use the com 5 or 6 you changed to free up com 1, then make your usb adapter use com 1 ?
                        jsut swap coms around?
                        edit freescan uses com1 only so if you having com probs then thats most likely what your problem is (freescan not seeing anything becuase its looking at com1 when usb is at com x)
                        • Syn
                          The Master Piece
                          • Oct 2005
                          • 599
                          #27
                          well i looked in the device manager and it doesn't say whats useing com 1
                          or i would of
                          it just says communications port(com1)
                          when i had it plugged in com5, i could choose com5 from the drop down box in freescan hmm
                          if its as simple as not being at com1 i am gonna go punch my car lol
                          • sil
                            4T60-E killa
                            • Nov 2004
                            • 723
                            #28
                            i dont know, i was told that freescan only worked on com1, i think craig from moates said that or maybe mick from gmpcm cant remember which, it was a while ago but thats what i was told :P
                            so its worth a try to get it to work on com1 hehe
                            • Syn
                              The Master Piece
                              • Oct 2005
                              • 599
                              #29
                              alright i am gonna dissassemble all my shit lol and drag it outside i'll let you know how it all goes rofl
                              • sil
                                4T60-E killa
                                • Nov 2004
                                • 723
                                #30
                                lol good luck !!
