questions,problems,eveything is never ending
  • Syn
    The Master Piece
    • Oct 2005
    • 599
    #31
    ha success and just in time i got done as the rain was starting to hit
    no troouble codes at all wtf? and it still ran like shit
    i got about 4 or 5 idleing ones and with a few revs. freescan would freeze sometimes
    my excel viewer for some reason won't open them
    i typed random letter for their names
    edit wtf only one opens in excel the others open in notepad with nothing on them
    and i can;t upload a csv on here i guess so wtf
    • sil
      4T60-E killa
      • Nov 2004
      • 723
      #32
      ya you get empty or repetative data ones when the software isnt communicating with the ecm properly
      also make sure if your taking more than 1 log, make sure you dont accidently click on a log file, in the save window, then rename, becuase that will rename and overwrite the file you clicked on.
      best to edit name in the filename field of the save log dialog
      takes a few clicks of the force data and sometimes it goes out int eh middle of a scan, so ya jsut gotta click it, and keep checking that the bytes are both moving
      so you have some datalogs !! its a start
      use filefactory, thats what i use, it keeps track of files you uploaded(if you register, for free)
      you can change the file extension to .txt to upload here if you want, then peeps can chagne it back to .csv after downloaded
      post up those logs !!! lol
      i have to go to the store with my wife, so ill bae back later hehe
      • Syn
        The Master Piece
        • Oct 2005
        • 599
        #33
        i clicked it alot lol it worked and everything was reading perfect everytime i hit log, so idk maybe freescan was being slow.
        anyways i changed the file type heres it in a text file.
        can someone save it and make it so i can open it in my excel viewer?
        incase when its changed u can't post it here my email is thesynster@yahoo.com
        uploaded it in filefactory and dind't even have to register
        FileFactory is the best place to upload and share files with no limits since 2005. Send and receive any type of file up to a massive 5GB with unlimited file bandwidth.
        • grandprixgtp_91
          • Nov 2003
          • 758
          #34
          hey you cant download the file off the site, you should just attach it in here if possible
          Jake
          • sil
            4T60-E killa
            • Nov 2004
            • 723
            #35
            Jake
            you can! :P the link is good, all you need to do is scroll down and look for where it says click here for free download its below the "Ads by google"
            edit
            syn, your log is currupted or something, i am able to open it in microsoft excel, but i am not able to open it in spread32
            if your intreested in spread32, its a great piece of free software for viewing the log files, if you cant view them in spread32 then sommin is wrong with the logfiles and you should take another log
            also i looked at your log and you have only about 200 lines of usable data, they are at the beginning of the file, and it hink they may be in open loop, best to datalog while in closed loop
            your o2 is not moving much, very slow... how old is your o2?
            your not running as rich as i am, which is a good sign
            your iac counts are lower than mine
            you had a knock count but no retard, you got it before you started logging, most likely was during startup, am i correct?
            does your motor windmill on startup, kinda catch a lil but not start?
            or is it quick start?
            your INT is moving up and down which is wierd
            it looks like you just started the car and datalogged jsut after starting it
            the log is short so there isnt much to work with, but its a start
            i bet a small decrease in bpw will get things inline, disable egr, disable calulate bpw at idle as function of airflow, disable ccp
            try to let the car enter closed loop, you can check if its in closed loop by looking in freescan on the "status bits" page there you will see it says closed loop when the light is lit its in closed loop
            then take some logs....
            idle log
            2000rpm steady rev in park log
            do about 2 min each on both and make sure that the freescan is connected and getting the data
            • Syn
              The Master Piece
              • Oct 2005
              • 599
              #36
              it said it was in closed loop when i took it, wierd
              the car was running for a few mins before i took the log
              my o2 is brand new its a 4wire heated o2
              i didn't log at all on start up
              idk what int is lol
              i blocked off my egr and the plug in is just sitting there in the engin bay
              so tomorrow if i have time i'll put some gas in it first since its like empty
              idle it at 2k for a few mins logging
              i'll do it a few times so i know for sure i atleast got one
              whats wierd is on my last datalog i basically logged right on start up and it said it was in closed loop lol?
              but no trouble codes which is odd.
              whats wierd is i've got it to run amazing about 2mons ago and got a few vids of it doing a 2nd gear burn forlike ever not trying
              but after 20mins and it got warmer it alassuden went to run like crap mode and hasn't real ran good ever except a few days
              • sil
                4T60-E killa
                • Nov 2004
                • 723
                #37
                have you done tuning to your bin ? "a custom chip" ?
                post up your bin file
                • Syn
                  The Master Piece
                  • Oct 2005
                  • 599
                  #38
                  nope stock programming, couldn't get a datalog how'd i begin to even start with a custom eprom lol
                  edit*
                  I do see a bright future in the next week or so for this car
                  mmmm custom eprom
                  • sil
                    4T60-E killa
                    • Nov 2004
                    • 723
                    #39
                    hey i made you a base custom bin file which disables...
                    Calculate bpw at idle as function of airflow
                    Disable egr
                    Disable ccp
                    this is where you start when doing tuning
                    do you have all the stuff needed to burn a chip yourself?
                    and more importantly put it in the ecm :P
                    you should buy ryan.hess' adaptor with the zif, and a few sf512's if you dont
                    • Syn
                      The Master Piece
                      • Oct 2005
                      • 599
                      #40
                      does anyone have the xdf file?
                      and thanks i'll take a look at it, i got another one thats got some stuff done to it i'm looking at.
                      i got a few friends with all the equipment so i'm gonna hoefully get some help from them soon
                      • sil
                        4T60-E killa
                        • Nov 2004
                        • 723
                        #41
                        cool, i wouldnt mind taking a look at the other one you got
                        can you attach it here
                        here is the xdf i have
                        its bare minimal but i would just add to it what i needed along the way
                        • Syn
                          The Master Piece
                          • Oct 2005
                          • 599
                          #42
                          thanks man! i have to talk to the owner of that bin to get verification to post
                          but as of right now i'm told its under raps
                          • sil
                            4T60-E killa
                            • Nov 2004
                            • 723
                            #43
                            ouu top secret :P
